Don't mean to side track you with Lower Volts and such.
I had written a post but the "Post Ghost" vapourized from my screen.
So .. Emergency allows a crawl mode for a big 90kW robot with 220kVA peak
to be taught/trained/educated by its programmers at say 5 to 40kW.
It is lower power that can be constrained better than 400 - 800V dc bus.
The full current would still be available even at low dc bus voltage.
The "brake IGBT" is a comman extra feature on controllers to slow the motor and the enertia itls moving.
The controller usually runs on 3phase and you can't regen it back to the grid.
So the controller has other options. A bit ... a tiny bit goes to the DC bus caps by upping their voltage.
But as the Caps charge up an extra IGBT can dump power into a Load Bank or resistor.
I don't know if the 5402 you have has it fitted.
The Beast is a multipurpose industrial "genie" they make 'em like "every wish is you command" when your build a industrail machine.
I think you've got a awsome drive system. I'm just blown away by the motor. I think the 100m Sprint may be wrong analagy.
At it's usual work load if any lumps come along it would just smash it flat.
Ah "The Beast and the Anvil"
Thinking about Delta or StAr.
Until you test the delta setup going to star is an optimization that will be a big effort.
Is it worth it???
All in the learning...
The eVo motor Could be a better Anvil for th Beast...
Looking at Geerants thread...
Evo Electric AFM-140/4
PM Ac motor 750Vdc would go well with the 850Vmax of the beast. The tritrium is limited to 450V.
the pdf has eff map on page 2
Geerant wrote: That seems to match this data as tested at Tritium with my motor.
This was done at 320v.
What delimahs you have...
EVO Motor http://www.evo-electric.com/inc/files/A ... t-V1.1.pdf
