- Real Name: Chris Jones
Post
by jonescg » Mon, 12 Feb 2018, 08:58
Brought to you by the AEVA
Only thing worth doing now is to see how much diesel is required to recharge the car to the same SOC (which is hard to do).
Rusdy
- Real Name: Rusdy
Post
by Rusdy » Mon, 12 Feb 2018, 13:13
I'm a bit lost. So 18kWh added to cover exactly the 104km distance? Was that pre-calculated so that the Tesla use 18kWh per 100km?
Post
by jonescg » Mon, 12 Feb 2018, 13:35
I think that was the intention. However from what Rob told me the driving conditions were near perfect, and both vehicles were using very little energy. They'd averaged 145 Wh/km even when driving at 110 km/h everywhere, so that 18 kWh wasn't used entirely.
It would be difficult to recharge the car to exactly the same point, because that point is somewhat fluid. If you recharge to 100% full you will use additional energy in cell balancing etc.
Maybe the next test is to effectively range-test the vehicle, with a generator nearby to provide the 5-hour full charge. Based on 266 ml/kWh that should require about 23 litres of diesel.
Rusdy
- Real Name: Rusdy
Post
by Rusdy » Mon, 12 Feb 2018, 16:13
jonescg wrote: ↑Mon, 12 Feb 2018, 13:35
...They'd averaged 145 Wh/km even when driving at 110 km/h everywhere, so that 18 kWh wasn't used entirely.
Ah, that's more like it. I didn't expect Tesla is that 'inefficient'.
What I didn't expect, how efficient diesel genset is. Converting 4.4 litre of diesel (around 44kWh of contained energy) to 18kWh translates to 40-ish percent energy conversion. That is pretty damn good.
So, from me the pedantic
, the correct diesel equivalent for the Tesla would be 3.7 litres then.
- Real Name: Dave Keenan
Post
by weber » Mon, 12 Feb 2018, 18:36
Now can we see how far the diesel runs on sunshine?
Rusdy
- Real Name: Rusdy
Post
by Rusdy » Tue, 13 Feb 2018, 09:45
weber wrote: ↑Mon, 12 Feb 2018, 18:36
My guess is 400-ish km. Sunshine --> Model X --> Diesel on Trailer.
Drag race it meanwhile you're at it. Please!
- Real Name: Richard
Post
by Richo » Tue, 13 Feb 2018, 12:33
TBH non-eV people would see this as 0.4L/100km of convenience to fill up a diesel car wheneva and whereva with more range.
Really who could be bothered to save 55c/100km for all that electric car hassle?
Just looking at it from the other side of the coin.
Diesel was sunshine once right?!?
Just jokin
- Real Name: Kurt
Post
by offgridQLD » Mon, 26 Mar 2018, 14:04
That's what I have noticed now that I am (temporarily) paying for grid power at 40c KWH our Imiev is about the same running cost as a 5lt /100km diesel car at $1.40 lt fuel cost.
That said the drivability of a EV wins hands down without $ savings or pollution benefits.
- Real Name: Kurt
Post
by offgridQLD » Mon, 26 Mar 2018, 14:17
I was thinking the same. Particularly if that's 18kwh into the Tesla battery. As it would have needed to produced more than 18kwh before charging losses. 4.4lt at $1.40lt for 18kwh = 34cent KWH less than grid power in SA
- Real Name: Matthew Lacey
Post
by antiscab » Mon, 26 Mar 2018, 17:20
Why is power costing you 40c /kwh?
2017 Renault zoe
2007 vectrix - 145'000km
- Real Name: Adverse Effects
Post
by Adverse Effects » Mon, 26 Mar 2018, 17:40
antiscab wrote: ↑Mon, 26 Mar 2018, 17:20
that is close to what i pay on the south side of brizzy as well
