Living in the past.
Posted: Thu, 07 Sep 2017, 12:26
It seems the forum server time is off...
My guess is 8hrs behind.
Is that a setting I can change or something you should change?
Re: Living in the past.
Posted: Thu, 07 Sep 2017, 15:29
by rhills
Hi Richo,
Not sure what time the Server OS is set at, but our Forum Software is set to WA time (just because I could!). However, each user can configure his/her own timezone in the User Control Panel -> Board preferences tab. I considered setting a default value for all users, but no single default was going to work for our Oz users, let alone our international users, so I left tha field empty. If you're showing 8 hours behind, I'd say that's set to UTC which is probably the default default!
Posted: Fri, 08 Sep 2017, 12:26
Excellent - that fixed it!
