Daihatsu Charade adaptor plate and coupling
Posted: Mon, 27 Oct 2008, 21:09
I hear there were several Daihatsu Charades at the AEVA AGM/field day. I have just got my engine out of my '91 G102 Charade and now I'm thinking about adaptor plates and couplings. I was planning to be clutchless. It occurs to me that someone may have already made all the crucial measurements for an adaptor plate and coupler which would save me doing it. Consequently, I might be able to order them from who ever made these parts previously without needing to ship the gearbox and motor, only the clutch plate with the splined bit. Am I in luck?
On a related matter I am planning to use an Impulse 9 motor. This is similar in specs to an ADC 8" but is shorter but fatter, in fact 9.25" diameter. I don't have the motor yet but have started to worry that I might be very close to having the boot or that other cylindrical lump on the drive shaft hit the motor if the suspension is compressed by a bump. I found one example of an ADC9" motor in a charade on the EValbum but the email bounced. The ADC9 has nearly the same diameter as the Impulse 9 so I think it should work but I would be keen to get an opinion from anyone who has a motor in this car and can tell me their engine diameter and the clearance they have.
Thanks,
Peter Campbell
Thanks,
Peter Campbell
