Hot rod EV - looking for advice.
blwnhr
Real Name: Adam
Re: Hot rod EV - looking for advice.
Post by blwnhr » Fri, 05 Apr 2019, 13:06
@Richo Yep, 1,385kg.
francisco.shi
Real Name: Francisco
Post by francisco.shi » Fri, 05 Apr 2019, 13:37
I made a webpage to work out acceleration and motor power.
You may like to play with it and see if it is useful
http://www.becman.com/MotorSport/index. ... calculator
I hope it helps.
Post by Adverse Effects » Thu, 11 Apr 2019, 21:38
Ribfeast
Post by Ribfeast » Fri, 12 Apr 2019, 12:33
That video makes me really want to build one of those now!
Post by Adverse Effects » Fri, 12 Apr 2019, 13:24
HAHAHAHAHAHA
sorry
blwnhr
Real Name: Adam
Post by blwnhr » Fri, 12 Apr 2019, 13:44
I had some time to play with the 3D model this arvo. I question its accuracy, it seems maybe 5% out, but as a proof of intent it's sound.
I grabbed the mounts off the subframe (purple) and moved them inboard to (a) see if it clears the drive unit and (b) determine if the mounts can still be picked up with chassis structure. The good news is, both seem true.
3D view
Left-side section
View of top arms from above
View of bottom arms looking up from underneath
Post by Adverse Effects » Fri, 12 Apr 2019, 21:09
your welcome
ROFL
blwnhr
Real Name: Adam
Post by blwnhr » Sat, 08 Jun 2019, 17:46
Hmmmm...what's in the crate?
Post by Adverse Effects » Sat, 08 Jun 2019, 19:55
OWWWWWW YOUR SHITTING ME!!!!!!!!!!!
is it?????
IS IT ???????
if it is i am sorry LOL and i carnt wait to see it and i carnt wait to see what you do with it AND i carnt wate to see the final out come
blwnhr
Real Name: Adam
Post by blwnhr » Mon, 10 Jun 2019, 16:04
Just the real subframe, brake to brake. I couldn't justify having a drive unit sitting around for X-number of years before I needed it. I have a known-accurate 3D model, I'll build one out of wood for setup. It came out of a write-off in Sydney, 2014 (MY15) dual-motor Model S. Someone posted the Gumtree link on the AEVA FB page, the stars aligned and I now have it under my house.
Assembled to make sure everything was there.
Brembo 4-piston calipers and Brembo park brake. The loom for the park brake is attached to the subframe and Google turned up a pinout, that means I can re-use this.
The front of the recipient truck is in the background.
The backing plates are cute.
I'll need to replicate these sorts of details, this is the wheel alignment adjustment.
Nice details cast into the subframe.
Post by Adverse Effects » Mon, 10 Jun 2019, 17:20
again I AM SORRY lol
looks good
blwnhr
Real Name: Adam
Post by blwnhr » Mon, 10 Jun 2019, 18:14
It has me excited for the project again. It helps not only having a supportive wife, but also some really supportive work colleagues (including mechanical engineers offering to do FEA on components I need to fabricate).
Travers
Real Name: Travers Wood
Post by Travers » Tue, 11 Jun 2019, 20:15
So cool and so green with NV for your EV.
Recipient looks very cool.
Can you just use it at the same track width (Wide track is always cool), I'd even say its easier to stretch a body than it is to narrow a drive train. (Worked many years agon with stretched and widened Range Rovers to UAE)
blwnhr
Real Name: Adam
Post by blwnhr » Wed, 12 Jun 2019, 04:58
In a nutshell, no.
The Model S is 1964mm wide, my pickup is 1928mm wide. While that's only 36mm, the Telsa also has no wheel offset which looks terrible on older vehicles. At a minimum I'd need to widen the rear guards 80mm-ish each side which would totally muck up the proportions of the car. In addition (under the hot rod build guidelines) I'm limited to a 10" wide wheel which further compounds "weird" look. Finally, having a rear track 226mm wider than the front will compromise the handling too much.
Post by Adverse Effects » Wed, 12 Jun 2019, 07:38
it is easy enough to shorten half-shafts its the frame mounting points are the hard part to move but not impossible
blwnhr
Real Name: Adam
Post by blwnhr » Wed, 12 Jun 2019, 08:59
As a hot rodder it's really very easy, we're used to fabrication like this.
In the coming weeks I'm going to have the subframe and suspension 3D scanned so I can build an accurate model to design a narrowed subframe to suit.
goingbush
Real Name: Don
Post by goingbush » Sat, 03 Aug 2019, 12:20
Nice truck, , totally missed this thread .
Have been looking for a '49 Pilothouse Dodge for my wife for about 25 years and finally a decent one turned up in QLD, been parked up in a shed for 20 years. Still waiting on it to be transported back down to Vic then I'll be able to figure out what needs doing.
And due to the success of my '73 LandRover EV 4x4 Conversion we will keep the Dodge outwardly original but convert to EV of course, this time I won't keep the gearbox but use a Planetrary reduction ( thanks for the Prado TC gear idea Francisco - I'll be in touch) then a driveshaft into rear diff. Will be a Local runabout , 100kmh / 100km range will be fine.
