Gear ratios and torque
Izabarack
Post by Izabarack » Thu, 11 Oct 2018, 14:02
I hope this is simple and a search did not convince me. Am about to install 1800 Watt 48 Volt Brushless motor turning 9 tooth cog, in a small quad EV conversion. Chain drive is intended to be to a 74 tooth cog on the rear axle. So a 8.22:1 step down. Ignoring losses, am I correct in thinking that 8 times the motor delivered torque will drive the rear axle?
Iza
Re: Gear ratios and torque
Post by jonescg » Thu, 11 Oct 2018, 14:21
Yep, that's correct. You are of course limited by speed now, so it won't be a particularly fast mover, but should move OK.
Izabarack
Post by Izabarack » Thu, 11 Oct 2018, 14:30
Thanks for the confirmation, just checking. The chain drive is based on relatively small T8F spec so I do need to check what that size will handle. The project is intended of kids to use on a bush block and I don't want them going fast anyway.
Iza
Post by Richo » Fri, 12 Oct 2018, 12:31
4500RPM -> 547RPM
3.8Nm -> 31.4Nm
I see some buggies get about 35kph, stand up scooters 55kph.
Izabarack
Post by Izabarack » Fri, 12 Oct 2018, 18:21
Those torque numbers are useful to me, Ta. Raw numbers I have produced suggest I should get about 38 Kph top at those ratios and rolling circ of the driven wheel. I'm on a steep part of the learning curve but having fun.
