LiFePo4 battery management
dat.ev
Post by dat.ev » Mon, 17 Sep 2018, 11:02
Hi folks,
I'm planning on a 33.2kwh battery pack consisting of 104x CALB 100AH 3.2v cells. One thing I have found is that most of the lithium BMS management systems support a maximum of 8 cells. Does this mean I need 13 individual BMS units? Is there a better way? Maybe there is larger BMS units out there Im not finding...
Thanks in advance.
Re: LiFePo4 battery management
Post by antiscab » Mon, 17 Sep 2018, 11:40
Www.zeva.com.au
Www.evpower.com.au
Batrium
Orion
Heaps to choose from that go up to 200 cells
2017 Renault zoe
2007 vectrix - 145'000km
dat.ev
Post by dat.ev » Mon, 17 Sep 2018, 11:46
I see the EV power one only goes up to 312v. Slightly low for my system. Zeva I can only see a max of 16 cells. Can you tell me where you saw the 200 cell one?
EDIT - Looks like the Orion can do it and you buy the controller based on cells required.
Post by Richo » Mon, 17 Sep 2018, 12:22
12 cells per module. 16 modules per CAN bus. 192 cells total (600V)
http://www.zeva.com.au/index.php?product=133
Post by Richo » Mon, 17 Sep 2018, 12:23
