Hi all,
Early next year I will be buying some ridgy-didge high voltage connectors from Amphenol.
Their catalogue can be found here:
http://www.amphenolpcd.com.cn/Upload/ue ... feb894.pdf
I plan on getting some for battery to inverter connections, but they do three phase motor connectors as well.
Pricing is about US$50 each for the plugs and $16 each for the shrouded receptacles. These are IP67 rated plugs, and 6k9k when plugged in (i.e. put underwater-able).
It doesn't get much cheaper with numbers, but the shipping and telegraphic transfer is a killer.
Industry standard HV connectors - any interest?
- jonescg
- Real Name: Chris Jones
- jonescg
Re: Industry standard HV connectors - any interest?
Quick follow-up - the company will do the oxygen-free crimping for you. So if you are interested in some of these, make sure you order it with a pre-set length of 35/50/70 mm2 cable.
- jonescg
I'm going to order 5 sets of 50 mm2, 2-pin, 90 degree HVSL1000 plugs and receptacles to match. If anybody needs one get in touch and I should have a spare to sell.
Chris
Chris
Possibly interested, what's the thickest size cable they can take?
- jonescg
These are already made up with 1.5 m of 50 mm2 cable. Good for 190 A continuous.
