EV200 vs LEV200 contactors
Stiive
Post by Stiive » Thu, 06 Jun 2013, 21:09
Does anyone know the difference between the LEV200 and EV200 contactor?
Rgds,
Stiive
Post by Adverse Effects » Thu, 06 Jun 2013, 21:17
sorry i just carnt help my self
that is easy one has a L in the name
like i said sorry just had to be done
Stiive
Post by Stiive » Thu, 06 Jun 2013, 21:28
EDIT double post
Rgds,
Stiive
Stiive
Adverse Effects wrote: sorry i just carnt help my self
Sorry, I just can't help myself.
That is easy; one has a L in the name.
Like I said, sorry, just had to be done.
Thanks.
It seems the LEV is bigger and cheaper. Doesn't seem to need an economiser [EDIT - has one included?], but uses more coil power.
Can someone confirm?
Rgds,
Stiive
zeva
Real Name: Ian Hooper
MSN: sigmunky@hotmail.com
Post by zeva » Thu, 06 Jun 2013, 21:49
Pretty sure that is the primary difference, the LEVs don't have a coil economiser so use a bit more power when energised.
I'm more a fan of the EV200. Using 2W instead of 15W for the coil means they run cooler and should last longer.
Ian Hooper
http://www.zeva.com.au
Post by Johny » Thu, 06 Jun 2013, 21:54
The data sheets also indicate the mechanical life is different (not that it matters for an EV generally).
LEV200 100,000
EV200 1 million
You can google both.
Stiive
Post by Stiive » Thu, 06 Jun 2013, 22:10
Hmm thanks.
Unfortunately I need a 24V coil, but it doesnt seem that Digikey stocks this in EV200
Rgds,
Stiive
Stiive
Post by Stiive » Thu, 06 Jun 2013, 22:14
Stiive wrote: Hmm thanks.
Ah never mind... its 9-36V coil.. digikey just lists it as 12V or 48V
Rgds,
Stiive
TooQik
Real Name: Chris
Post by TooQik » Thu, 06 Jun 2013, 23:44
The open and close voltages are also different between the two. For example, the 12 VDC LEV200 has a close voltage of 9 VDC and an open voltage of 2 VDC, while the EV200 is 9 VDC and 6 VDC respectively.
The EV200 is also about 150 grams lighter if you're looking to save some weight. Image
These are all according to the data sheets I've read.
Post by coulomb » Fri, 07 Jun 2013, 03:00
I believe the L version is longer, as well.
So: L is longer, heavier, more power, but cheaper.
Stiive
Post by Stiive » Sun, 09 Jun 2013, 18:02
Thanks guys.
Didn't want to experiment and stuck with what I know.
EV200 for main contactors + LEV100 for pre/dis-charge
Rgds,
Stiive
