The pics should tell the story well enough - it's an elevated work platform used in an apple orchard, it uses skid-steer with 2 driven wheels and a castoring one, and has a hydraulic ram for lifting the boom (ignore the air tank etc. it isn't used and I'd remove it as part of the conversion).
It strikes me as a good candidate for conversion as it spends most of the time stationary.
At the moment it has an 8hp motor and the travel speed of the machine is a bit slow (less than walking speed) whereas brisk walking speed would be preferred.
The pics show the pedal control system which uses rods down the boom to engage v-belts which send power down the shafts on each side to drive the worm reduction gear on each wheel. Obviously I'd look to mounting the motor (plus chain or gearbox if needed) direct to the input of the wheel gearbox. Being skid steer and driven in both directions, it'd need symmetrical speed control, which doesn't seem that common.
Any ideas on how feasible this is, or advice on how to ascertain what size motors I'd need on each wheel?
