any transformer experts here ?
HeadsUp
Real Name: Mark W
Post by HeadsUp »
anyone got opinions what this might be ?
it has no markings for input or output voltage
looks like 2 mm and 3.5 mm thick copper strip windings , the 3.5 mm thick winding has 3 taps , the other thinner one has 2 taps
probably ex navy
45 kg all up , measures about 28 cm long x 15 cm wide
how can i test it ?
just stick an adjustable power supply on one end and see what jumps out the other ?
HeadsUp
Real Name: Mark W
Post by HeadsUp »
only found this from googlisation
web page without much info :(
lithbattboss
Post by lithbattboss »
Could be some kind of welding transformer by the looks of it. With such heavy windings it is probably a low voltage , high current output transformer which would be typical of a welding transformer.
Where power matters.
www.lifetechlithium.com
Squiggles
Real Name: Neil
Post by Squiggles »
My guess is it has a centre tapped high current secondary winding.
If you use a variac as your adjustable supply you should have no trouble working out the turns ratio. If you put 24V in you might get something like 5V - 0V - 5V out.
Just thinking... at 45kg did you say ? and an auto transformer it would be maybe 20+kVA rated. If it were a typical mains auto transformer voltage range of say 230 to 110V then the 110V would be at 20,000/110 = 180A thus the large copper strap wiring.
Auto transformers are roughly 1/3 the weight of isolating transformers.
I would not expect this item to be anything to do with voltages <100V. Even then, consider the CSA of the copper, allow maybe <5A/mmsq in a transformer, possible kVA rating and go from there.
No harm in putting AC at some low voltage (24V?) into it and having a poke around. Remember the iron losses may require you to supply several Amps just to get things going.
A way I have used to establish the voltage of a winding is to use a variac with current monitoring in line and raise the voltage looking for a knee (current rises sharply). That will be magnetic saturation of the iron core and working voltage will be less than that depending on transformer design. Typically 75% of the knee voltage. You can also look at the output voltage and see it reach a top knee.
Take care not to overload the variac and don't try to do this under load. Image
Did I see reference to 400Hz ? That puts the power rating up by a factor of 8 !
HeadsUp... email supplier time. Image
EClubman
Real Name: Mark
Post by EClubman »
Definitely a Decepticon.
(sorry :-)
HeadsUp
Real Name: Mark W
Post by HeadsUp »
acmotor wrote: Did I see reference to 400Hz ? That puts the power rating up by a factor of 8 !
thankyou peepil
yes
400 Hz
so possibly airforce equipment for its light weight , will let people know if i get a reply on specs from the USA
i have found references to them on US websites which specialise in aeronautical surplus but no other specs yet
Might I ask what you want to do with it?
At 45kg I doubt you'll be putting it in an eV for charging...
Peter C in Canberra
Real Name: Peter Campbell
Post by Peter C in Canberra »
It does say autotransformer on the label. Is there continuity between all terminals? That would mean one long winding. Maybe it is for transforming mains voltage at modest current (on the two smaller terminals) down to very low voltage at very high current (on the two large terminals)?
HeadsUp
Real Name: Mark W
Post by HeadsUp »
Richo wrote: Might I ask what you want to do with it?
i have a constantly open mind always looking for ways to use what i find around me.
its worth $ 65 in scrap value , so thats what i paid for it , hoping that might obligate the risk of me not finding a use for it in an EV or a mini hydroelectric inverter on the farm i am looking at buying
thanks for help
i will stick 40 - 240 VAC on it when i get a chance and see if a naked genie pops out the other end
optimism never hurts !
