Thunderstruck charger. Time for fun
Dan007a
Real Name: Daniel Andrews
Post by Dan007a »
Got my tsm2500 charger today. 3 days from LA to the Pilbara wa.
Got a evv 2.4 just waiting to confirm if it will do type 2 or stuck with type 1 ..
Im a bit happy atm
Re: Thunderstruck charger. Time for fun
Got photos?!
Dan007a wrote: Wed, 24 Jul 2019, 18:51 if it will do type 2 or stuck with type 1 ..
It looks like a type 1 (J1772) setup, as is common in the USA with their single phase preference.
But all you probably need is a cable like this one to adapt a type 2 EVSE to what I presume will be your type 1 socket:
https://www.aliexpress.com/item/3272397 ... 4c4d60zu1o
I use that cord with my 2012 Leaf, which has a type 1 socket.
Dan007a
Post by Dan007a »
No socket purchased yet. Been informed by thunderstuck.
The EVCC 2.4 can handle J1772. To connect with Type 2 J1772, customers have been manually grounding the proximity wire (12v negative) to start the charge. Hopefully that will work for you.
Best,
John
Dan007a
Post by Dan007a »
Just had a play with the canbus.
Reminds me of my old Amstrad
10 goto line 30
20 go to line 10
30 go to line 20.
Lol
Or dos
Dir/w
