Stray Capacitance
Posted: Wed, 28 Feb 2018, 22:07
Sometimes when building a battery, we like to put it inside an aluminium enclosure. We go to great lengths to ensure there is a non-conductive surface between the enclosure and the cells and hope that nothing is touching.
But we measure the voltage between a terminal and the chassis and we see a voltage - sometimes in the tens of volts - which rapidly decreases as the resistor in the multimeter drains it.
I notice this on my first bike, which had A123 pouch cells held inside an aluminium enclosure. Old video here:
As a complete battery, fully charged to 117 V DC, I could often measure 100 volts between the chassis and the positive or negative terminal. It would give me unpleasant shocks leading me to drop tools where I shouldn't. From this point on I started to use polycarbonate as an enclosure material and never had an issue, even with a 700 V battery on Voltron.
But recently I've been looking at soaking heat out of the battery pack using a good thermal conductor like aluminium and the issue of capacitance comes up. I built this battery, due to be finished shortly, using machined ally plates. It will be 117 V when fully charged. But even with Kapton, electrically insulating, thermally conductive epoxy resin and sizable gaps between conductors and the case, I measured a few volts between the terminals and the enclosure.
Fortunately it's not that high, and I don't think it will be an issue in terms of safety or electrical interference, but I got to thinking about how some battery designs just don't lend themselves to aluminium enclosures due to stray capacitance. Any voltage between two conductors has the potential to build charge. And when a solid aluminium case makes a conductive path from one end of a hundred-volt battery to the other, it's possible that charge will accumulate. Perhaps the worst case would be a battery like this:
High potential, close proximity between conductive plates, and a dielectric that may or may not be all that helpful. Basically, there is a good reason Voltron's battery enclosure is made out of polycarbonate, as the charge build up would be significant!
What do you think? Any design features that would help alleviate the issue of charge build up on your enclosures?
