Well finally some of the Toshiba's SCiB Lithium Titanate batteries are hitting the open market.
Here is the link to Toshiba's spec on the cell.
http://www.scib.jp/en/product/cell.htm
The ones that seem available are the high power 2.9Ah 2.4V cells.
They claim testing at 10C charge and 10C discharge continuous with over 40,000 cycles.
A peak current of 200A puts this in at 65C
As a handy feature it has screw terminals and standardised bus bars.
So no messing about with manky pouch cell tabs!
They seem to be priced around the $12 mark in one-off's.
So this is about Double the price of headways/Wh
But given the higher fill factor with the SCiB and higher peak currents could be worth it in some applications.
Toshiba LTO SCiB
- Richo
- Real Name: Richard
Toshiba LTO SCiB
- jonescg
- Real Name: Chris Jones
Re: Toshiba LTO SCiB
Been following these for a while now - great to see they've hit the market.
Interesting cell architecture too - looks an awful lot like the cells used in the BMW i8
AEVA National President, returning WA branch chair.
- Richo
Claimed peak power is 420W which means peak power is at 60C.
So a 2kWh($3,500/44kg) pack would have 120kW peak.
And with normal use 40,000 cycles...
All they have to do now is make the internal battery structure last 100 years.(shelf life)
Nice vid.
I like how they use a blow torch on the batteries at every chance.
And stick the batteries together with double sided tape.
Even the robot picks the batteries out of the box slowly.
Agreed.
I thought that was plasma for roughening the surface, so the adhesive sticks better. But I didn't look closely.I like how they use a blow torch on the batteries at every chance.
- Richo
You're probably right - I've never seen anything exactly like that.
The start of the vid shows samsung as the battery supplier so they wont be Toshiba or possible even LTO's.
They look similar tho.
- jonescg
Just read that BMW uses Samsung SDI to make their prismatic cells for the i3.
