AC charger with solar edge
linux geek
Real Name: Arden
Post by linux geek » Tue, 26 Dec 2017, 07:44
Hi there in in the process of building a 10kWh power wall from recycled 18650 cells
Problem I have is charging them effectively as my new inverter is solaredge plus don't want to loose my UK subsidiary for solar production
My current plan is to install a pip 4048 sense when im exporting using a pi then get this to tell the 4048 to start AC charge and set the current depending on export. Then power house at night via a changeover switch.
Wondering if I'm overcomplicating things or if someone has already done something similar.
Thanks in advance
Geek
Re: AC charger with solar edge
Post by jonescg » Fri, 29 Dec 2017, 20:18
What voltage are you aiming for? 48 V I assume? 14 in series and about 60 in parallel?
I suspect an inverter-charger or hybrid inverter will do what you want quite nicely.
If the inverter doesn't have a battery input then you will need an AC to DC (240 V AC to 48 V DC) charger, and a separate inverter to turn the 48 volt DC into 240 V AC for running the home.
