Charging ThunderSkys
hyper24
Post by hyper24 »
Can someone point me in the direction of charging info for the thundersky batteries.
Im designing my own charging system, hopefully it will be very cost effeftive and simple enough for anyone to build. Ill start up a DIY charger thread with pictures and all.
Before you start thinking "outside the box" you better have a good understanding of what's "inside the box".
commanda
Real Name: Amanda Wynne
Post by commanda »
If you're talking BMS, I'm currently building one similar to this one;
http://endless-sphere.com/forums/viewto ... 12f49d60ff
for my 16 x TSLFP40 for my EVT scooter. Charger is 3 x 24 volt 6.5 amp switchmode supplies made by meanwell. The controller part of the BMS has 2 constant current sources in parallel, 4 amp & 2 amp. Initial bulk charge both sources are on, charging at 6 amps. Once any cell reaches float, the 4 amp source switches off, and charging continues at 2 amps until all cells reach float. 15 minutes later the 2 amp source also switches off. Currently under construction, shake-down testing this weekend. BTW, my cells arrived today; woo-hoo.
Amanda Image
Evt-4000 (Big Lithium grin)
Chopper pushbike 180 watt Cyclone
charging for thunderskys is basically
cc at 0.3C then cv at 3.7-3.8vpc.
the when current falls to 1A (i think?) cv at 3.5-3.6vpc.
