Battery 10,000cycles 100%DOD
Not particularly suitable for an eV but is a taste of things to come.
http://www.infinitepowersolutions.com/i ... 110920.pdf
40C max
10,000 cycles 100% DOD
100,000 cycles 10% DOD
zeva
Real Name: Ian Hooper
Post by zeva »
Richo wrote: Not particularly suitable for an eV
Assuming a typical 250wh/km energy consumption, one of those cells could move an EV approximately 4cm Image
And it seems like it only works out to 10wh/kg energy density? But still interesting tech, for sure.
Ian Hooper
http://www.zeva.com.au
zeva wrote: ... one of those cells could move an EV approximately 4cm Image
Still, not bad for the *volume* of about 3 postage stamps!
[ Edit: OK, make that about 6 stamps; you'd need two layers by very rough calculations. ]
I'm too lazy to check, but it sounds plausible; I'd say the insulation /packaging becomes a significant faction of the cell mass at the 2.5 mAh size.
We'll have to downsize from microcars to nanocars Image
Works out to 36 Joules.
Given that a 10F cap could easily do the same job you would only buy the battery for the size and voltage consistancy.
Still if they started stacking in larger formats and had 10k+ cycles that's a pack that is in for the life of a car!
