hi all
just found a suppier for the super capacitor's in aus
http://www.glyn.co.nz/Power_Elec_Maxwell.htm
waiting on prices
supercapacitor battery's
- Real Name: sean crust
s.g.crust
I would be interested to hear prices.
those caps are useful where you need high power for less than a second.
when the discharge time is extended to around 3 seconds their power density is the same as AGM lead acid and low rate lithium batteries.
energy density is very bad, but thats not really what they are used for.
what application did you have in mind for these caps?
Good points Mat,
...mmm trying to figure out what starts to deflate.
Just note my calcs below get more complicated than I was expecting.
I hope they're on track.
Main point is the spec W/kg is only available when the Module is fully charged. So the energy density is not just the problem.
So 1000kg in 0-100km/h in 10 seconds takes
( oh I forgot to include losses, mainly wind resistance)
how many watt-hours = work done = F x d = Ma x d = M.a^2 x t^2
a = (100/3.6)/10 = 2.778(m/s^2)
d = a x t^2 = 2.778 x 10x10= 277.8 m
W = 1000kg x 2.778 x 277.8 (Joules) = 771728.4 (Joules)
W = 771728.4 /3600 (W.h)
W = 214.4 Wh used in 10 seconds to get to 100km/h
Energy stored in a capacitor E = 1/2 x C x V^2
But what is the power needed from the cap when the voltage has dropped down to say 1/4 of the fully charged state.
So for the BIIG baby Model: BMOD0063 P125 has Max nom voltage of 125V and C = 63F so Energy is 136.7 (W.h)
But they suggest available Energy is from Full to half voltage of 101.7 Wh
It can sustain 150A with fan running.
The power at full charge is P=VI
(P@Full V)= 125 x 150 = 18.75 kW
(P@ 1/2 V)= 62.5 x 150= 9.375 kW
(P@ 1/4 V)= 31.75x 150= 4.6875 kW
(Also, as the Rint = 18mOhm, so Losses P@150A = I^2 x R = 150x150x18[mOhm] = 405W)
So power needed for same acceleration at 90km/h to 100km/h of 2.778 (m/s^2)
P(@ 100km/h) = F.v = M.a x (v[m/s])
= 1000[kg] x 2.778 [m/s^2] x (100/3.6)[m/s]
= (Ek)/s = 77.167 kW
So with 2 Maxwell BMOD0063 P125 in Parallel for 250A and 63Fx2=126F combined.
What is the voltage with depleted energy of 214.4 Wh (or 77.167 kJ)
Eo-Ea = 2x136.7[Wh] - 214.4 = 59 Wh remaining
V = √(3600 x 2 x E[W.h] / C) = √(3600 x 2 x 59 / 126)
= √(3371.4) = 58 V
So to power the acceleration with only 58V
I=P/V = 77.167[kW] / 58[V] = 1330 A
(way over continuous Amps, but near 1sec rating of 750A each)
So using Energy available of 101.7 Wh per module.
And that for 1/2 Voltage Power of 67.5V x 150A = 10.125 kW
To get 1000kg to 100km/h in 10 seconds needs at least
19kW @ 25km/h
38kW @ 50km/h
77kW @ 100km/h
So for 77kW, V = P/I=77kW/150A=513.3V
So for 1/2 Voltage of 125V = 67.5V, 513.3/67.5 = Current factor 7.6
But Voltage will not have fallen this far.
for 6 modules(6x63F) and depleted energy calc for Voltage
Eo-Ea= 6x136.7 - 214.4 = 605.8 Wh
V = √(3600 x 2 x E[W.h] / C) = 107.4 V
P = 107.4 x 150
for 8 modules(8x63F) and depleted energy calc for Voltage
Eo-Ea= 8x136.7 - 214.4 = 1093.6 - 214.4 = 879.2 Wh
V = √(3600 x 2 x E[W.h] / C) = 112.1 V
P = 112.1 x 150
Oh stuff it - spread sheet used:
From Quadratic Solution of solving Power Max =
Ki 2.38 A/F
Vmax 125 V
Ea W.s=J 771840 214.4 Wh
Pmax 77000 W
Module Cap (F) 63 F
n BEST 5 (~4.96)
Farads 315
Er = 1689097.5
Er [Wh] 469.19
Im 750
I per Module 150
Vm 103.56
Eo [Wh] 683.59
Eavail [Wh] 512.7
So 5 Modules required in your choice of terminal voltage would get you a high performance EV if your batteries are strictly limited to say 1C rates. ie 20kWh pack at 120V, C = 10k/120 = 83Ah,
so for 1 hour drive at 60mph 322Wh/mile = 200Wh/km (say MX-5)
gives 100km trip at 100km/h
(I need to factor in the contribution from the batteries but at 83A/750A of only 11% it's not much during the fast accelleration)
But I hate to think of the cost of 5 of these for 0.5kWh for 300kg , plus the 20kWh Battery back to get you from A2B.
Life cycle 1million Start/stops to Stop/Starts Cycles
3 years = 1095 days so just don't do 1000 per day.
But I wonder how many I would do?
I think a graph in the "BOOSTCAP® Ultracapacitor Modules" spec would be very helpful that shows the power available as the voltage/energy is released. And a 10sec current rating would be vey nice too.
We expect them for batteries, motors and controllers.
It's more complicated than I thought it would be.
I think I might do a non-linear spreadsheet calc so I can change values especially car weight and accel time. Once I catch my breath from this lot.
My track record lately for dumb mistakes is pretty high so I'm hoping i've missed something and these mighty caps are much better.
= √(3371.4) = 58 V
19kW @ 25km/h
38kW @ 50km/h
77kW @ 100km/h
P = 107.4 x 150
P = 112.1 x 150
Ki 2.38 A/F
Vmax 125 V
Pmax 77000 W
Module Cap (F) 63 F
n BEST 5 (~4.96)
Farads 315
Er = 1689097.5
Er [Wh] 469.19
Im 750
I per Module 150
Vm 103.56
Eo [Wh] 683.59
Eavail [Wh] 512.7
I found price on MOUSER site
BMOD0063-P125-B14-01
AUD$14,000 x 5 = AUD$70,000 i'm sure they could be built up from singles BOOSTCAP's with monitor PCBs for cheaper
3000F/ 2.7V
@ $174 for 3Wh of full storage.
500Wh/3 = 166 qty
166 x 174 = $29000
+PCB+link/5 is $120 = 166/5 x $120 = $4000
Prices still crazy. They need to be tenth the price!!!
Maybe they put some of these in the iMIEV
Edit Cheaper price at
Tecate group 3000F/2.7V @$76 50up
3000F/ 2.7V
500Wh/3 = 166 qty
166 x 174 = $29000
try using maxwell boost caps in series with your battery pack in a buck boost converter con fig to buffer the battery bank (maybe regen)this may help efficiency/longevity of the battery pack.
Prices for super caps
Dear Sean,
Thank you for your enquiry.
Below is the price for 13pcs of the 16V 250Farad BMOD0250 P016 modules.
Standard lead time ex Maxwell factory is 12-15 wks and should you need them sooner than this I will need to check and confirm.
Part No: BMOD0250 P016
Description: 16.2V, 250F (107168B)
Qty/Price
MOQ 3pcs USD750 (AU$840) each
13pcs USD695 (AU$780) each
Delivery: 12-15 wks aro
TNT Road freight to Brisbane:
3pcs (13.5kg) AU$55.00
13pcs (58.5kg) AU$185.00
Best regards,
Dean Sarelius
Australian Sales Manager
Glyn Ltd
Suite 7/201
29-31 Solent Circuit
Baulkham Hills NSW
Australia 2153
Ph: +61 2 8850 0320
M: 0437 877 001
Dear Sean,
Qty/Price
Best regards,
Dean Sarelius
Glyn Ltd
Suite 7/201
Baulkham Hills NSW
Australia 2153
Ph: +61 2 8850 0320
M: 0437 877 001
s.g.crust
