Elcon charger can communication error TCCH-72-25-CAN1009
Laloe
Real Name: Eloy
Post by Laloe »
Hello
I have an issue with Elcon charger TCCH-72-25-CAN1009 that is driving me crazy. I need some help.
My old elcon charger stopped communicating with the BMS, and gives an can error communication with flashing green -led flashing leds.
I read the can message with usb to can interface and i am getting : Id: "6A1" and message 00 00 00 00 10 00 00 00"
Message looks fine: is giving a can error communication (that i was expecting it) but the Id 6A1 it doesnt make sense to me i was expecting something like "18FF50E5"
Also i tried to send every second id 1806E5F4 and 02 D0 000A 00 000000 but i do not get any result
I suppose that the error is that elcon has "lost the id ". could you give me any idea were the issue could come from and how to solve it? Would be elcon can bus interface or the processor on the charger?
Thanks in advanced!! if i solve this i would be forever grateful!!!
:mrgreen:
Re: Elcon charger can communication error TCCH-72-25-CAN1009
Laloe wrote: Sat, 10 Oct 2020, 19:00 I have an issue with Elcon charger TCCH-72-25-CAN1009 that is driving me crazy.
I'm not familiar with the CAN1009, only CAN1000. Was the last digit a typo?
That's pretty weird. It seems to me that the CAN box isn't reading the serial data from the charger properly.
That's requesting to charge at 72.0 V; that won't charge a nominal 72.0 V battery at all. The Elcon's often misread the battery voltage by several percent; often I find I have to ask for a higher voltage than I want to actually charge at. The charger wants to work mainly with current.
Does sending the packet change the LED pattern at all?
I haven't had my head in this space for a while; try to find the exact pattern for comms error (note: some of the manuals are misleading or flat out wrong) and make sure that is the error that you are seeing. There are several patterns that involve red and green. Some have gaps between, others don't. From a quick search, these are the two you are likely to run across:
  • RGRGRGR - Communication error (CAN Bus only).
    R - G - R - G - Battery not connected or out of specification or DC output fuse blown (or waiting for CAN command).
That seems unlikely; the IDs are burned into the firmware. I have a "Unican" firmware (almost universal firmware that should read the various limits from EEPROM) that you could try as a last resort. But first try charging by sending a packet with say 75.0 or even 80.0 V (at 1.0 A, that should not overcharge your battery unless you keep doing it for hours) and see if anything happens. I don't expect it, since if it's in state zero, it will not charge. My memory is hazy but I'm pretty certain that the R - G - R - G - pattern means it's in state 0.
Laloe
Real Name: Eloy
Post by Laloe »
Is not a typo error CAN1009
No, is still giving communication error pattern (RGRGRGR - Communication error (CAN Bus only)) also it is still sending message error message 00 00 00 00 10 00 00 00 where 10 means Communication error
i tried but still i got communication error
It looks really interesting , could you give me some info about it so i can try?
i tried to connect directly to 7 pin connector with the arduino "interface" circuit that you posted several years ago (the one with two optos) but i am not able to read anything, so now i am trying to prepare the serial interface to 7 pin connector , so lets see if i can read something dorectly on the charger .
Also i checked charger optocouplers and it looks ok. I do not know if i should get rid of the gloo in the canbus interface and check the optocouplers or something else
Thanks!
