Michelin wheel motor
Benonymous
Real Name: Ben Roberts
Post by Benonymous »
Expect to see more EV products coming out of mainstream industry.
http://www.michelin.co.uk/michelinuk/Af ... s_Id=23759
Gow864
Real Name: (John) Gary
Post by Gow864 »
I guess they had no problems dyno testing then.
Bring it on.
Electrocycle
Real Name: Andrew
MSN: dumhed@dumhed.com
Post by Electrocycle »
interesting concept, using "normal" small diameter, high rpm motors instead of a large diameter low rpm motor.
This would reduce unsprung mass, allow much easier liquid cooling, and make it a lot easier to add a simple two or three speed planetary gearbox to the motor, allowing a broader efficiency range.
I like it :)
Post by woody »
That's a 195/55R16 tyre for scale.
The drive motor is offset, I assume this gives a Portal Axle type gear reduction like a Unimog, which could easily give a 10-15:1 reduction ratio with a small percentage loss.
I like the bit of wood or sponge in the outside shot, and the 6 wire connector which stops it rolling away in the inside shot.
Shows that the engineers are still working on it :-)
cheers,
Woody
Post by woody »
Tree Hugger says the whole setup weighs 43kg each wheel.
Per axle 35/24kg unsprung (front/rear) compared to a Clio with 38 kg unsprung on the front axle seems better, but the cynic in me thinks the Clio was chosen because it has the highest unsprung weight around :-)
