To import or to build? New to EV's
Re: To import or to build? New to EV's
Post by mikedufty »
Mikeymcblimey wrote: Tue, 17 Sep 2019, 13:43 Personally I just don't like the sports style
Sports style? I thought they only did standard / classic type styling?
Mikeymcblimey
Post by Mikeymcblimey »
The ones I saw looked sporty
So there is another thread where a QS hub motor was used.
http://forums.aeva.asn.au/viewtopic.php ... 641#p68955
The 8kW hub motor was used as that what fitted width-ways I Believe.
The QS site has 8kW, 10kW, 12kW and 14kW.
However the only difference I could see was the kV rating - and you can specify this when ordering!
So I don't know how real the 14kW motor is.
http://www.cnqsmotor.com/en/article_read_378.html
As mentioned in the other thread 8kW has trouble maintaining 100kph.
So if you're not interesting in maintaining highway speeds and happy with cruising around these do look like a good option.
