EV Motor Durability
Outsidethebox
EV Motor Durability
Post by Outsidethebox » Mon, 23 Oct 2017, 18:27
Hi there,
how durable and what sort of life expectancy would I be expected to achieve for a 130 hp (approx) EV motor operating under constant load 24/7. My aim is to run a 240V Alternator off an EV Motor to replace household mains power and increase capacity for other projects i have underway. I had thought to power the motor with multiple battery packs integrated with a charge sensor / switching arrangement to swap packs when a preset charge depletion level was reached - The offline packs would then be charged either by mains or off the alternator and obviously i would require enough capacity to enable 24 hour operation taking into consideration recharge times and battery depletion rate. Given the alternator would have an RPM requirement of 1500 RPM i had also thought to run the motor through a suitable reduction box to achieve the required RPM and greatly increase torque.
Are EV components suitable to perform this task or is the cost : Life ratio not going to work? Any help is appreciated or even a point in the right direction if i'm in the wrong place for this discussion.
cheers
Re: EV Motor Durability
Post by Adverse Effects » Mon, 23 Oct 2017, 20:05
what your asking is impossible
you carnt run a electric motor off a battery bank to run a generator to charge the battery bank and stay power/energy positive
am i getting what you are saying correct?
Outsidethebox
Post by Outsidethebox » Mon, 23 Oct 2017, 21:09
i see where your going with this but i'm trying to stay as far away from perpetual motion arguments as i can and i'm not trying to cheat the laws of thermodynamics. If my alternator needs 120 horsepower to operate at 1500 rpm under maximum load then the driving force (EV Motor and Battery Packs) needs to be slightly greater taking into account mechanical inefficiencies - for the sake of the discussion let's say 130 horsepower.
As in an EV car the power for the motor is supplied by the battery pack - i want to use the same method so the motor is not reliant on the alternator for power but on the battery pack. I want to use additional separate battery packs to achieved sustained operation. Separate battery packs also enabling me to charge the packs not currently in use. The battery packs can be charged off mains power thereby reducing my power bills to a bare minimum.
My original question was whether EV components could sustain the constant operation and what life span could i expect. I hope i have cleared that up somewhat
Post by antiscab » Tue, 24 Oct 2017, 00:11
All motors have a continuous rating, just stay below it. I have a 6.7" x91 motor in my shed that would normally be used in a daihatsu charade size conversion. That's rated to 14kW continuous.
2011 Blade Electron mk6
2007 vectrix - 145'000km
1998 Prius - needs batt
Post by 4Springs » Tue, 24 Oct 2017, 04:37
A DC EV motor? Wire it for shunt mode (so you don't need a controller) and keep an eye on it to make sure it doesn't overheat. Should last for a long time.
120 horsepower (90kW) is a huge load. That's 39 10A outlets at full capacity. antiscab's 14kW motor would only do one sixth of that power. Do you have a 240V alternator already? - that would be a monster!
Why an EV motor? Wouldn't an industrial motor suit this purpose better? Get one to match the speed of the alternator so you don't need a gearbox and all the losses involved with that.
The other question is - why not just use an inverter? Much more efficient and (I'd assume) cheaper than the setup you describe. Plus quicker to respond to varying loads, uses no power when there is no load, no moving parts to wear out, can sense the state of charge of the batteries...
Post by 4Springs » Tue, 24 Oct 2017, 04:43
To give you an idea of the inefficiencies of a DC motor, I ran the DC motor in my car at one point without load to wear in the brushes. 17 hours of running with no load used 15kWh of electricity. Extrapolate that out to 24 hour a day operation gives 21kWh required per day just to keep the motor spinning.
Post by Richo » Tue, 24 Oct 2017, 13:00
1500RPM 100kW would be 636Nm continuous - which is pretty hefty - as you say a gearbox would be needed.
You could so it with off the shelf industrial stuff:
800kW PV solar panel
565V battery pack 3.6MWh
110kW+ Induction 3-phase Motor drive (controller)
TWO(2) x 110kW 3-phase induction motor 6-pole 1000Nm 1000kg
So this would convert solar with a days storage into 3-phase 50Hz 100kW isolated output 24/7.
Are you really sure you want 100kW continuous 24/7?
Post by Richo » Tue, 24 Oct 2017, 13:06
The the price on the above would be around $700k.
Motors would last 10-20 years.
Solar 20+ years.
Battery 8-10 years.
But TBH this is enough for 160 regular houses...
:lol:
Post by Richo » Tue, 24 Oct 2017, 13:08
Actually it wouldn't...
The the isolated induction motor would need an exciter.
