the i-MiEV experience
You know how the turning ignition key (what an ancient name) to 'start' powers off the Nav, I guess to simulate ICE proceedure, well is there more to it that upsets the Nav ?
Seems there is a brain transplant as well as geographical re-indoctrination on the eclipse site. I'll wait for someone else to try it though. Image
i shall try to use my work telstra 3gs iphone more.
it has sat nav already in it as long as there is a 3G signal :|
only thing is that there is no warning when one is over the speed limit on the phone :|
Is there a warning that you are using the phone while driving ? Image
Just found out after 2 years that the cable in the glovebox is an iPhone/Pod connector.
charges and communicates properly with the stereo
I was using bluetooth audio before and powering the iPhone via the 12VDC socket.
only thing is that if you connect the iPhone when the stereo is turned on, it swaps to the iPhone input
this is what happens in the volt
I guess that it assumes that one wants to play some tunes.
the volt doesn't have bluetooth audio streaming.
another sat nav error:
sat nav says to turn right into Northside Nissan from Wanneroo Rd heading north, but there is no opening in the median strip.
http://youtu.be/davBx9n62M4
Car sharing for seniors
Another missing road Edward st in nedlands
It also reset the satnav
It is a Bermuda triangle.
http://www.youtube.com/watch?v=QhLIwOlB_kM
more car sharing in belgium
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 77
