2 Speed Gearbox
2 Speed Gearbox
Andrew funny you should say put the diff and simple gearbox together, because I was thinking that very same thing last night. A cast alloy housing with a 2 speed gearbox incorporated would be just the ticket. Compact design, oil all in one place, no clutch, cable gear select...
2 Speed Gearbox
Post by mikedufty »
My subaru ICE has a two speed gear box between the main 5 speed and the wheels (it is dual range). Would such a dual range transfer case be useful for electric vehicles? The subaru ones can be shifted while driving, unlike some bigger 4WD that require you to stop. The liberty is only about 10% reduction, which might not be enough to be useful, I think the older models, brumby etc had a bigger reduction.
2 Speed Gearbox
each car uses a different diff though, while the gearbox could be the same.
I think there's a point where the extra efficiency is outweighed by the project being too specific, making it hard to be commercially viable.
2 Speed Gearbox
I agree on not including with the diff. Most likely it would be for an independent rear end which would rule out us solid rear end folk.
I reckon just a 2:1 and 1:1 would do it as most motors would be Ok to 4000 RPM which would be max. required speed for 1:1.
If possible, two pre-ordered ratios would make it cope with everyone's requirements. If not, maybe two or three choices?
2 Speed Gearbox
I drifted off onto a more adhoc approach there for a sec, but if we are talking a commercial consumption, then yes a limited gear ratio options would be necessary to work with different diff ratios.
It wouldn’t necessarily have to be done completely from scratch, if the right gears could be sourced from an existing deployment, it would cut costs. That would be the preferred option since it is one less part you need to manufacture.
Mark T
Real Name: Mark Taylor
2 Speed Gearbox
Post by Mark T »
We have a member here in Sydney who works for a company that designs and builds gearboxes. It may be worth having a chat with him at the next meeting.
2 Speed Gearbox
um yeah, that would definately be a worth while contact.
stuartri
Real Name: Stuart Richards
2 Speed Gearbox
Post by stuartri »
Thanks for your reply Taffy.
There is a lot of information on youtube on the device. It is manufactured by fallbrook technologies. Very easy to setup. I am incorporating it into me new design which I am hopful to run at the EVChallenge this year. Missed last year as started a new job and could not attend.
I have attached a picture of the unit. Still need to fit the disk brake.
Regards StuartImageImage
AMPrentice
2 Speed Gearbox
Post by AMPrentice »
mikedufty wrote: My subaru ICE has a two speed gear box between the main 5 speed and the wheels (it is dual range). Would such a dual range transfer case be useful for electric vehicles? The subaru ones can be shifted while driving, unlike some bigger 4WD that require you to stop. The liberty is only about 10% reduction, which might not be enough to be useful, I think the older models, brumby etc had a bigger reduction.
this kind of transfer box I never knew existed it would be ideal to study if it works as you say it does. There are many of subarus at wreckers and can you tell us the model?
Maybe it could provide a base for a 2 speed?
2 Speed Gearbox
Very nice for a bicycle but not for a car.
If you look at thier website they have torque and RPM limitations which make it unsuitable for a car.
Also they say it has "Automotive" applications but is still vapourware.
They say for LEV upto 5kW.
Don't really need a CVT on my lawnmower...
Also please note that although it may be a CVT they don't specify the efficiency.
My concern is that what you make up by keeping optimum motor power you will loose in efficiency through the CVT.
As for the eVchallenege you would need to test the efficiency to see if it is worth while.
Otherwise you could be better off with a single gear, bigger motor and more caps.
esp with a $1200 price restriction...
2 Speed Gearbox
the Subaru transfer case is built into the main gearbox if I remember correctly.
There's just an extra selector lever going into the gearbox.
stuartri
2 Speed Gearbox
Post by stuartri »
Thanks for your reply Richo.
In respect of your comments for the EVChallenge I would agree with you regarding a fixed sprocket arrangement as we won the 2007 challenge on exactly that configuration. Our record still stands.
My motivation for the unit is more for a general commuter than a purpose built EV Challenge racer.
I will be able to comment on performance when I get it integrated as I have a development agreement for the unit.
PS it would be one great lawnmower though lol
Regards Stuart
2 Speed Gearbox
You need a development agreement to use it?
I'd be interested in efficiency tests.
In comparison to the hub gears rohloff & shimano types it is about half the price.
moemoke
Real Name: Andrew Pugsley
2 Speed Gearbox
Post by moemoke »
This topic seems to be splitting in two!
I think the Subaru transfer box is part of the gearbox and they are used
in all 4wd manual models from the 70's uptill now (I think)
Suzuki lj80- Sierra had a seperate hi/lo transfer box (as do most older 4wd's) but I'm not sure the ratios would be suitable for using as a gearbox and whether they could handle the power without going through a gearbox first also some transfer boxes can only change gears with the vehicle stationary. what bout using an old 3 speed Holden/Ford/Valiant gearbox, atleast you'll have reverse which can come in handy.
fuzzy-hair-man
2 Speed Gearbox
Post by fuzzy-hair-man »
Electrocycle wrote: each car uses a different diff though, while the gearbox could be the same.
I was inclined to agree but then I though that Azure's gearbox is a gearbox / diff combined (all be it with a single ratio) and evidently they make it sell??? If you had something like the planetary where you could select one of 3 ratios even if you couldn't change gears it would be a pretty useful product I'd think?
OK so this is probably specific to front wheel drives and Azure have the American market to sell into, and we don't want to leave the rwd guys out in the cold but for a front wheel drive taking drive from the motor into a 2/3 speed box which has prop shaft like inputs and outputs and then onto a diff is all using up precious space, so I think unless the gearbox mates flush up to the motor or is integrated into the diff it's not really going to work space wise for front wheel drives. Image
Edit: changed could to couldn't in: 3 ratios even if you could change gears...
2 Speed Gearbox
Not quite what I had in mind, but this might come in handy for anyone wanting to step up or down their gearing / change drive direction http://www.tolomatic.com/products/produ ... gear-boxes
That is the simplistic design I am talking about. If we could keep that level of simplicity and just add another changeable gear it would be perfect.
2 Speed Gearbox
moemoke wrote: This topic seems to be splitting in two!
agreed.
I started the following thread for discussion of the smaller CVT's here:
viewtopic.php?t=1068
fuzzy-hair-man
2 Speed Gearbox
EV2Go wrote: Not quite what I had in mind, but this might come in handy for anyone wanting to step up or down their gearing / change drive direction http://www.tolomatic.com/products/produ ... gear-boxes
Going off the graphs in the full catalog here (10.4Mb) these gearboxes aren't able to cope with revs over 1200 rpm so they might be a bit small, the peak torque it can deal with seems to be 2500 inch lbs = ~282Nm
at least that's what I get from the graph below:
2 Speed Gearbox
As I said not “exactly” what I was looking for, more along the lines of what would be ideal in concept. Have a look at the guts of it, how much simpler could you get?
On the home page you will note they custom build. You could provide them the specs you need it to be to meet the motor requirements and have them make a batch of them.
gttool
Real Name: Geoff OToole
2 Speed Gearbox
Post by gttool »
Yes I have looked at building a 2 speed gearbox for when i do the bike conversion looked at using both a planetary configuration or coventional gear train
for the bike i was going to use a cone clutch possibly ,on the bike as an example using the clutch lever as a gear change it would be normally in the high gear, pulling on the clutch would disengage the clutch and low range would be selected ,sounds simple enough hopefully find enough time to build a sample
after testing of that would follow on with a larger 9" version
I could machine the small gearbox from billet no problems would Be inclined to cast the larger box
Geoff
fuzzy-hair-man
2 Speed Gearbox
Oh sorry I wasn't dissing it they look quite cool and useful I just went looking for more info and if they would take the torque and RPM required and just posting back what I found, they do look a neater and smaller way of making drives do 90 degree bends than belts or chains. Image
Taffy
Real Name: Taffy Flynn
2 Speed Gearbox
Post by Taffy »
Just seeing if anyone has made any more progress?
The best looking CVT i found was the nissan tordial CVT, they are stacked end to end to give you other gearing options
http://www.carbibles.com/transmission_bible_pg2.html
Gemini
2 Speed Gearbox
Post by Gemini »
Ive just been watching video's of CVT's and am amazed. Engineering is amazing!
AMPrentice
2 Speed Gearbox
some kind of cvt has to be the way or......
a box like say the mitsubishi lancer which are virtually indestructible and have small form factor.
It needs to be a box that is able to lose 3 of the gears and synchros and allow the use of say only 3rd (2 to 1) and 4nd (1 to 1) and reverse.
Gemini
2 Speed Gearbox
Post by Gemini »
How about one of these CVTs ?
http://www.youtube.com/watch?v=R8AzqtomwD0
