AEVA Homepage
  New Posts New Posts RSS Feed - VFD on PMSM
VFD on PMSM
 Post Reply Post Reply
Author
Message
Richo View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Topic: VFD on PMSM
    Posted: 12 August 2016 at 11:02am
Has anyone tried a PMSM (Brushless AC) motor on a standard VFD sub 2.4kW?
I know that some of the washing machines have direct drive motors that have magnet motors with sinusoidal BEMF.
I want to try test one with an off the shelf VFD.
Normally the VFD is for an induction motor so and many of them don't mention if they will work with a PMSM.
Is it a case of setting the name plate ratings ( v /f) and go?
Back to Top
Johny View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johny Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2016 at 11:16am
I can't answer your question for sure but my opinion is that it will not work unless the VFD has BLDC or PMAC as a setting.
It will try to establish magnetising current in the rotor - no idea how that will damage the permanent magnets.
Maybe if it has the option of no magnetising current that may infer that it'll work.
Lotta maybes...
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2016 at 1:18pm
Yep looks like your right.
A VFD will only work on a PM motor if it has the code for it.
A standard IM VFD wont work.
I had thought setting the slip to zero.
But I'd say it's still has the wrong motor model to run the PM motor.
Worse still some VFD say they can do PM motors but the fine print says it requires a firmware upgrade to do it!
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2016 at 1:24pm
Back to Top
  Share Topic
This page was generated in 0.213 seconds.
