AEVA Homepage
Forum Home Forum Home > Technical Discussion > Technical and conversion discussion
  New Posts New Posts RSS Feed - That thing that sucks
 Post Reply Post Reply
Author
Message
Richo View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Topic: That thing that sucks
    Posted: 23 September 2016 at 4:19pm
Anybody got any updates, hints or clues to some you beaut Vacuum pump for the brakes?
I'm sure I saw some Billet ali ones a while back but can't find them anymore.
Back to Top
poprock View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote poprock Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2016 at 6:17am
Hi, purchased a s/h UP28, I think from a Golf, from US for $50A; I have the upper cutout set too high and with a reserve tank 100m dia and 300 long it gives 14 pumps before switching in. The booster is only small (Suzuki Carry). Check out the OHMBOY build on the net.Same vehicle as mine but a much better conversion.
" A little foolishness now and then is relished by the wisest men "
Back to Top
TooQik View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TooQik Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2016 at 4:45pm
This is where/what I bought for my conversion:
https://www.summitracing.com/int/parts/hla-009286001/overview/
Can't give you any details of how well it works as it's still sitting in its box due to my conversion being stalled.
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote poprock Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2016 at 6:06pm
Wow, makes a s/h one attractive. Why not trial a used one to see if it meets your requirements?
Back to Top
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TooQik Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2016 at 9:12pm
I wanted the larger UP30 over the UP28 and couldn't find one second hand, albeit I didn't spend a lot of time looking.
The UP28 seems to be used a lot in vehicles, while the UP30 is harder to find.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2016 at 12:29pm
Yeah I did see the Hella one's and "unbranded" Hella ones - which weren't much cheaper.
What about the electric cars such as the Lead etc?
Surely they must have something usable.
Quite a few mention that they are only for supplementary use.
ie cars with poor vacuum.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2016 at 12:34pm
To make things worse some OEM vacuum pumps don't clarify that they aren't for brakes.
ebay 310720630307 is actually for the vent controls!
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2016 at 12:44pm
331274996988 This one is the UP28 - AUD$203 delivered.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2016 at 12:55pm
Back to Top
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TooQik Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2016 at 1:47pm
This is why I went for the UP30. To quote from Hella's website:
"These pumps are able to supply the necessary vacuum independent of the engine technology. The UP30/32 supplies a vacuum to the brake booster, and when required, to the engine compartment actuators. The UP30/UP32 is installed in the pneumatic section of the brake system, just like the UP28. Both vacuum pumps are ideal for vehicles without any vacuum, such as hybrid/fuel cell, electric or diesel engines."
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2016 at 12:39pm
Originally posted by poprock poprock wrote:
(I) purchased a s/h UP28
Any ideas on how noisy it is?
Although it's unlikely I'll hear it over the sub
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2016 at 1:05pm
Supposedly the VE commode has one.
Wonder how much the wreckers charge for them...
The UP28 appers to be used on the Holden Cruze.
https://www.summitracing.com/int/parts/hla-009428081
http://www.bettabuyone.com/catalog/product_info.php?manufacturers_id=18&products_id=8206&osCsid=jm50lcp6nejksionq0ml018qn2 $165
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote poprock Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2016 at 6:41pm
My up28 is much quiter than the Gast which was previously fitted. Think of a flock of pigeons passing overhead compared to the Westpac rescue chopper with full pitch.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2016 at 5:19am
Well I have to get something because I'm too lazy to push hard on the pedal
Was on the Hella website and they list 3/4 different models.
The main difference is the UP28 take ~12secs to suck out a 4L to 70% and lasts 600 hours whereas the UP30/UP32 takes half the time but lasts twice as long.
The UP5X is marginally quicker and lasts a bit longer again than the UP30/32.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2016 at 12:11pm
Here are the specs on all the Hella Vacuum's:
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2016 at 12:19pm
I have ... a reserve tank 100m dia and 300 long
So 2.3L.
I have read some other ppl (non-ev ppl) that didn't bother with the reserve tank.
I'd be a bit skeptical about no-tank in peak start/stop traffic.
2L sounds a reasonable size to have.
The tech specs suggest the UP28 is the quieter of the bunch.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2016 at 9:49am
So I ended up getting a UP28.
Any one know off hand the part numbers for the matching connector?
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote poprock Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2016 at 5:28pm
I used Auto One over the counter fittings. The UP28 is in a container where the 12v battery was originally fitted, so no worries with moisture. The RMS engineer mailed the paperwork today, so hopefully blue slip inspection next week. Rear transmission seal leaking; so will replace first. Still way too much vacuum reserve; must adjust one day.
Back to Top
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TooQik Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2016 at 8:38pm
If it's the same as the UP30 then the connector should be a Yazaki 7283-5575-10 or equivalent.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2016 at 12:44pm
Yeah that looks like it
Shipping alone will be more than any other connector I could shove on there.
Or cut One off a wiring loom from a wreck.
Typical
Back to Top
  Share Topic
This page was generated in 0.281 seconds.
