AEVA Homepage
Forum Home Forum Home > Production Electric Vehicles > Mitsubishi
  New Posts New Posts RSS Feed - Recalls 2016
Recalls 2016
Author
Message
Gabz View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gabz Quote  Post ReplyReply Direct Link To This Post Topic: Recalls 2016
    Posted: 30 June 2016 at 6:05pm
https://www.recalls.gov.au/content/index.phtml/itemId/952859
I think my I-miev got all 3 recalls, for this year. haven't contacted the dealer yet.
Back to Top
mikedufty View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikedufty Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2016 at 9:52pm
Mine's got two. Might have road salt in the vacuum pump breather from all this snowy weather we've been having in Perth.
And horror of horrors, a dirty indicator switch.
Back to Top
g4qber View Drop Down
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2016 at 6:40am
yay!
I'm a "winner"
http://www.caradvice.com.au/458197/mitsubishi-australia-recalls-430000-vehicles-mitsubishi-colt-challenger-i-miev-lancer-outlander-pajero-triton-affected/
my 2011 is already in the shop waiting for Mitsubishi Australia to decide on what to do with cell 17, etc.
Edited by g4qber - 01 July 2016 at 6:44am
2011 i-MiEV - 87k kms
2014 i3 REx 90k kms
Back to Top
offgridQLD View Drop Down
Avatar
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote offgridQLD Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2016 at 7:11am
I think the only one worth looking into is the bottom side cover plate for the motor controller.
I think the above issue could have been the reason a few people had random parts replaced in an attempt get to the bottom of that one cars not charging and other HV or cut out (limp mode issues).
Would be interesting to see what they actually do to fix the issue or if its just a check and monitor thing. Good to see they got to the bottom of a issue like that.
Be buggered if I ever want to take my car into them though over small things.
The exhaust port on the vacuum pump was most likely orientated incorrectly when they replaced all the factory fitted pumps on the last recall. I will take a look at my pump and rotate it if it looks exposed. I have very fine talcum powder like dust all over the engine bay of my Imiev (due to dirt roads)
Back to Top
thardy456 View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote thardy456 Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2016 at 10:27am
Yes hate taking car to dealer for a recall issue, they always try to sell some extra work while it's there....
Cheers, T.
2010 iMiEV (ex-WA)
2013 Leaf
2006 Prius itech
6kW solar PV.
Back to Top
reecho View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote reecho Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2016 at 3:31pm
They didn't replace all the vacuum pumps in the last recall. Only selected VINS....
Edited by reecho - 01 July 2016 at 3:32pm
Back to Top
Avatar
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote offgridQLD Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2016 at 9:39am
Well cant be that then.
I take it that the fix will be inspecting the pump and ensuring the exhaust port it orientated so it's pointing sideways and perhaps slightly down. Vs directly up to collect water or straight down to have road spray shot into it.
Though will have to inspect it and see how it's set up. Perhaps even a shield would help. Not that we have much salt in the mud or road spray in AU.
Back to Top
Gabz View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gabz Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2016 at 3:55pm
I got 3 letters today
Back to Top
Hippie403 View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hippie403 Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2016 at 4:01pm
I got two recall letters, firmware for vacuum pump and the light stalk fix. Plus an extra surprise at the dealer, removal of the pan under the battery pack and treatment with anti corrosive paint, that kept the car in the workshop all day, when I was expecting to have the car back in an hour or so! Grrrrr.
Back to Top
Avatar
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote offgridQLD Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2016 at 4:07pm
Are you sure it was the battery cover? As that's made of plastic. So is the battery box. The only steel there is the mesh screen between it and the plastic battery box and its' stainless steel mesh that's riveted to the plastic pan.
There is a recall for the bottom plate of the motor controller.
Edited by offgridQLD - 27 July 2016 at 4:08pm
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hippie403 Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2016 at 5:00pm
My VIN was outside the range for the motor controller recall. They had some large black cover plate off from the bottom of the car, masked off some areas with cardboard and spray painted some stuff under the car, don't know exactly what.
Back to Top
bmscott View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmscott Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2016 at 6:51am
I took my iMiev in several weeks ago (soon as I saw this thread in fact) and they said they'd have to order parts for it - so finally, last week I get a call, and the other day I took it back in. Everything seems OK, I just found the long delay a bit odd.
Looks like they replaced the vacuum pump, did something about rust on the drive battery frame, and "Electrical" - campaign 020127 ON BOARD CHARGER. Sounds like a goodly amount of work done in ~5 hours.
They also whacked in a fender I'd knocked partway out banging into my wife's car last month, which was nice of them.
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikedufty Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2016 at 10:24am
Anyone in WA got it looked at yet? Mitsubishi web page says our nearest authorised EV service place is in Adelaide.
Back to Top
antiscab View Drop Down
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2016 at 10:52am
My Dad took his iMiev to paceway mitsubishi
That's where I bought it from originally
2011 Blade Electron mk6
2007 vectrix - 117'000km
1998 Prius - needs batt
Back to Top
iDaVID View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote iDaVID Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2016 at 11:28am
When I took my 2010 Miev to my dealer, it turned out there were 5 recalls not just the vacuum pump. It took them 3 & 1/2 weeks to fix them all.
Back to Top
zzcoopej View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote zzcoopej Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2016 at 11:35am
I hope you weren't without the car for that period? Our iMiEV is heading in tomorrow, they said it was just an exploratory stage (whole day!!!) and would need to go back if any issues were identified. Our local dealership is hopeless however it would be PITA to take the iMiEV elsewhere like I do with the PHEV.
2010 iMiEV
2015 PHEV Aspire
www.evpositive.com
Back to Top
Avatar
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote offgridQLD Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2016 at 12:20pm
3rd option is just not to take to them at all. The car has performed perfect for almost 5 - 7 years 2010 or 2012. Why fiddle with it..... Unless it was for some doomed structural failure point in the steering or life threatening issue it all sounds to hard to me . Just to have dust cleaned from the indicator stalk and paint sprayed on the battery box frame.
Back to Top
bladecar View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote bladecar Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2016 at 8:32am
My car is driving well and reliable, and I know what an unreliable car is like.
My car has 4 recalls and I've been around the industry in the past and would prefer to let well-enough alone. I prize my car and I don't want people learning on it.
I decided at the last moment to simply not go ahead with the recall. The Mitsubishi man said, to paraphrase: "So I'll tell Misubishi that you don't want your car upgraded then?" (which I think was uncalled for, but reinforces my view of the way things are) and, untrue as it is, I said "Yes."
Back to Top
Johny View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johny Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2016 at 8:55am
Just watch out for insurance ramifications. If an insurance company can find any link (stretch or not) that a non-recall contributed to an accident then you may be out of pocket several thousand dollars.
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote zzcoopej Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2016 at 7:24am
20MI010107 Turn signal correction
20MI010101 ECU Reprogramming - brake warning lamp
20MI020129 Rust on battery frame
20MI010102 Vacuum pump replacement - brake warning lamp (new pump is noisy?)
TODO : 20MI020127 On board charger (ordered part)
2010 iMiEV
2015 PHEV Aspire
www.evpositive.com
Back to Top
chuckchunder View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuckchunder Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2016 at 10:05am
Yep took it to Paceyway. They told me five recalls inc inspect/replace the battery frame. after a couple of hours told me they needed to replace the battery frame, which would take five or more hours. They had to order the part and would call me (or maybe you matt?) when it was ready to go.
Then they told me the "main" battery had failed the test, and would I like them to replace it today?..........
the antiscab's dad
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote reecho Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2016 at 10:18am
Well that's unfortunate......
Back to Top
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2016 at 11:09am
For a pack that's had no noticeable decline in capacity, this feels like a fishing expedition
might see what they charge for a new pack where I get to keep the old one.....my blade could do with a new battery, as could my solar system :p
Back to Top
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuckchunder Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2016 at 11:42am
Him - "Hi sir, we've done the recall blah blah blah........ and as part of the recall we perform a safety check on the vehicle, and your main battery has failed the test, would you like us to replace it today?"
Me - "choke, cough, er, sorry, what?"
Him "The main battery has failed the test, but we can replace it for you today...."
Me - "Really? Um, do you mean the traction battery or the accessory battery?"
Him - "You know, the main battery, the one that runs the windscreen wipers and radio and things"
Me - "Oh, er, no, that won't be necessary."
the antiscab's dad
Back to Top
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2016 at 12:37pm
oohhh dear
so, when they said battery frame - I wonder if they were just talking about the 12v battery frame
Back to Top
  Share Topic
