AEVA Homepage
  New Posts New Posts RSS Feed - New Blade Electron owner
 Post Reply Post Reply
Author
Message
antiscab View Drop Down
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Topic: New Blade Electron owner
    Posted: 29 June 2016 at 10:25pm
Hi Guys,
I appear to have been on a electric car collecting spree of late
Greg from Queensland was kind and generous enough to give me a Blade electron - thankyou Greg
It has a couple of gremlins I'm trying to chase down, but am a bit short on detailed info on the Blade cars
This particular one has the TM4 motor and controller
Does anyone happen to have any info on Blade Electrons that they're willing to share?
2011 Blade Electron mk6
2007 vectrix - 117'000km
1998 Prius - needs batt
Back to Top
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2016 at 10:52pm
I found a manual here:
Electron Manual
Back to Top
jonescg View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonescg Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2016 at 7:29am
You have it in Perth Matt? I'm going to be up for the WA branch AGM in August. It would be great if you brought it along to the meeting (assuming you sort the gremlins).
Back to Top
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2016 at 10:55am
I sure do
at present it is un-registered (it was easier to bring it across that way)
There's a bit of a vibration when driving in second gear that I need to look into before I can think about taking it over the pits.
I've only driven it around the block, but another issue that I have yet to replicate is power drops to a quarter intermittently. I'm thinking dodgy pot box, but hard to diagnose when you can't observe the problem
Back to Top
jeff ev View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeff ev Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2016 at 9:29pm
I have an early Blade Electron , the drop in power in mine is as a result of low battery pack voltage ,when it gets below 179v it will drop the power significantly (which allows the voltage to go up and gives full power which drops the voltage ect.ect.) Cheers Jeff . [Someone else has a Blade EV in the aeva, eastern states]
Back to Top
Bryce View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryce Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2016 at 4:11pm
I have the electrical drawings for the Mark 5: pm me your email & I'll send them.
Bryce
Current EV drives:
2011 Leaf
2001 Berlingo conversion
Past drive:
2011 Blade Getz
Past Conversions:
DC Berlingo, AC Berlingo, AC Sprinter
Back to Top
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2016 at 9:56pm
ooo, yes please
I have a Mark 6, there may be some similarities between the two models
Back to Top
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2016 at 12:33pm
Update, after some panel removal, I have identified the bms as an Orion unit. Cell count appears to be 100 cells, however, the whole battery is mounted underneath the car, imiev style. I have yet to be able to identify what cell size or construction it is.
Range appears to be down to 45km, with actual capacity around 7kwh
Does anyone have an Orion bms? If so, do you have the usb can cable?
Back to Top
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2016 at 10:45am
Update:
The vibration has progressively become worse, and now the car is dead :(
interestingly, the motor no longer spins even when the gearbox is in neutral.
I haven't had a chance to pull it apart to inspect the mechanicals of it - pictures to follow when I do.
Does anyone else here have a motor/controller manufactured by TM4?
I'm in need of diagnostic tools (so I can see what the controller is reporting)
Further inspection reveals the use of a Tritium EV Driver Controls module.
Back to Top
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2017 at 6:37pm
Update, I have started opening up the dead electron to see what can be salvaged.
The battery has turned out to be 108 series 20 parallel 26650 lfp cells of unknown origin. They're marked as 10.25wh
I'll need to do a capacity test. I had plans on pulling out the battery, repackaging and using it as a second battery in my other electron. Not so sure on that now, until I see how this giant spot welded and glued together thing comes apart.
Back to Top
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2017 at 6:43pm
Edited by antiscab - 17 June 2017 at 5:53pm
Back to Top
  Share Topic
This page was generated in 0.250 seconds.
