AEVA Homepage
  New Posts New Posts RSS Feed - My Motor Died
My Motor Died
 Post Reply Post Reply
Author
Message
4Springs View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4Springs Quote  Post ReplyReply Direct Link To This Post Topic: My Motor Died
    Posted: 08 February 2017 at 6:01pm
I had to call the RACT today and be towed home!
I heard a noise, then the light came on on the dash that indicates the thermal switch on the motor has closed. This is a switch in the motor somewhere that I connected to a likely-looking disused dash light.
I coasted to a stop and opened the bonnet. Could smell a burning smell. Tried to run the motor in neutral but it did not turn at all.
Once I was home I took off some covers and had a look. Found that one of the four sets of brushes was lop-sided, and one of the brushes was disconnected.
The motor is a Kostov.
1st photo is of the two brushes I took out (they sit next to each other). The longer one is more or less how it should be, but the other one has been warn right down. It was jammed in its cradle on an angle. You can't see it from the photo, but the lug on the wires on that one is quite bent as if it had been hit, or probably pulled by the brush.
Next photo shows the thing the brushes sit on, as well as the bracket for the brushes I removed. I don't think there is any damage here. I felt for score marks with my finger and didn't feel anything.
The next photo shows one of the other three sets of brushes. They all look undamaged as far as I can see.
The last photo is of the bracket again. It looks a bit lopsided, but so do the others.
I've taken the brushes out to see if my local motor re-winds workshop can supply replacements.
Any advice is welcomed.
What could cause this?
Do I need to replace all the brushes at once?
Am I likely to get replacements locally, if not where would I go?
What do I need to know about installing new brushes?
Is there any other damage I should be looking for while I'm in here?
Back to Top
evric View Drop Down
Admin Group
Admin Group
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote evric Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2017 at 7:29pm
I had a problem the the top set of brushes in my ADC X91-4001 motor and had replacements made by cortela.com.au Ron Rigg (0432762530) is my contact.
I replaced all the brushes at once, but then bedded them in for about 20 days continuous running on a 12V power supply (about 40Amps)
See YouTube video Barina EV.
The spring tension needs to checked so that it is the same on all.
The problem may have come about from the brushes not being bedded in in the factory. I reckon that was my problem.
Edited by evric - 08 February 2017 at 7:31pm
Back to Top
nuggetgalore View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuggetgalore Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2017 at 7:43pm
I heard a noise,
I would not spend time and effort in replacing the brushes without making sure there is no damage to the commutator. If only one segment is dodgy,it will burn out completely or rip it and its neighbors out. The commutator probably needs to be machined, looks rather shocking.
tinker
Back to Top
Johny View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johny Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2017 at 6:15am
I agree with Andreas. That commutator looks pretty burnt.
My GUESS is that the brush stuck in the brush holder, overheated, burnt the comm, and finally fractured from the heat. Just a guess though.
A good motor shop will test the commutator and, if good, machine it slightly to clean it up. My guess (again) is that the comm is still good provided the segment insulation is still OK - not too burnt.
Again, the motor shop should be able to get replacement brushes that can be ground to size.
Back to Top
Richo View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2017 at 12:33pm
I'd probably take a look at the spring assembly.
If one side is pushing much harder then it will wear out quicker.
Then the brush went past it's wear limit and rattled around until it jammed up on the commutator.
The bracket the brush sits in one side of the top is shiny like the spring had been resting/bouncing on it as the brush had worn down too far.
Just as a side thought there are 4 sets of brushes.
Shouldn't it still run, with reduced power, with 2 sets removed?
There's probably an excess of carbon buildup on the commutator.
Wiping it of with IPA or blowing out with on air gun may help.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2017 at 12:44pm
Also any ideas how may km you racked up before it blew?
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4Springs Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2017 at 5:35pm
I like this theory, the motor rewinds guy did too. You can see that one of the springs is sitting at a different angle than the other one. The end of one of the springs was also burnt off by arcing.
I took the brushes and springs to a local motor place, along with the above photos. For some reason I had deleted the photos from my phone, so I had to bring up this forum to show him the pics!
He said that yes, he'll be able to get some brushes made if I can get him all the specs on the motor. He said that from the photos the commutator will need to be machined, and that if I get it turning (i.e. with the new brushes) he can give me a thing to do that with (sounded like a sharpening stone).
He looked at the picture of the un-damaged brush and said that it would be best if I replace all of them.
With regard to Eric's comment on the bedding in brushes, I watched his video when I bought this motor. I went and watched the motor in the dark and could see no sign of any sparks. So I decided that the brushes were bedded in ok.
I've also called Tim at EV Works to see if he has brushes. He hasn't called me back, so I guess he doesn't have any in stock. He did say that he had a local company that could make them.
This motor is only new, it's done 22,000 km.
Back to Top
Admin Group
Admin Group
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote evric Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2017 at 10:38pm
Hi Christopher,
In my video the sparking stopped at 21 hours of "bedding in" and then the brushes required another 249 hours of "bedding in" until they matched the commutator.
My motor had done less than 20,000km before the brushes were distroyed.
Eric
Edited by evric - 09 February 2017 at 10:41pm
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johny Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2017 at 7:17am
A lifetime ago I user to do field service on 150HP DC Motors - in extruders and suchlike.
When we changed brushed we had a bedding stone that we simply held on the comm (with the motor running slowly ~= 500RPM) for 30 - 60 minutes until the brushes took on the shape of the comm. (We stopped motor every few minutes and had a break while the brushes were partially extracted and checked.)
I guess these motors were never exposed to the large overloads that EVs subject them to, but we never had a failure after brush replacement.
Bad brush fitting (by factory sparkies), sticky brush holders and detensioned brush springs (due to taking partial motor current) were the major problems.
Even if someone expert replaces the brushes, check them yourself for correct fit and sticking (lift slightly by pulling on brush wires).
I guess that's why I went AC
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2017 at 12:33pm
20,000km is a rough yearly travel for an average commuter.
What is yearly servicing like on an ICE? $200-400/yr
So I guess if the brush set was less than this then your still in front from a maintenance point of view.
I guess it's just the inconvenience due to usual repair work required.
You could always buy another set once the first set is up and working.
That way if it happens again you could be up and running in no time.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johny Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2017 at 3:07pm
The brushes aren't worn down though. This was a failure.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4Springs Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2017 at 4:34pm
I just remembered - I have a set of brushes in the shed!
This is because I have a burnt out Kostov K9 motor. I replaced the K9 with a K10 so that I wouldn't burn it out. Same manufacturer, would they just use the same brushes in all their motors?
So I went and had a look, pulled out a brush and took it to the K10. The K9 brushes are similar in all dimensions except for width. The K10 brushes are significantly wider, with much thicker wires on them. The K9 brushes would rattle around in that cradle.
The bedding stone that Johny mentioned sounds like what the motor rewinds guy was talking about. How do you hold it on there without getting yourself electrocuted?
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johny Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 7:00am
I have a vague memory of strapping it to a piece of wood.
I also have a clear memory of blowing the s%&t out of an SCR controller when it slipped and somehow lifted a brush momentarily (or something - can't remember why). It wasn't me holding the bedding stone...
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4Springs Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2017 at 3:09pm
Ok, still waiting for anyone to return my calls on getting brushes.
In the meantime, and as suggested, I cleaned out the commutator using compressed air and then isopropyl alcohol. Then I inspected it carefully and took some photos:
There was a lot of dust. I suppose you get that when you have worn one brush down by about 2/3. Now that I've done this I realise that this is something I should have been doing periodically (blowing it out with compressed air). If I had done so I might have noticed something funny about the dodgy brush.
In that third photo you might be able to see a line along the middle. I assume this line is from between the brushes. I assume that eventually, after many years work this line would become pronounced. At the moment it is just a line.
The commutator looks intact and feels very smooth. There are some notches though, that can be seen on the third photo in particular. I can feel these with a fingernail in the groove, but can't feel them with the balls of my fingers over the surface. They are not just slivers, they don't come off with my pick tool. They mean that the sections are closer together than they should be - is this something that should be fixed?
Then there are these bits:
Having never inspected this bit before, I'm not sure if this is how it always looks. Parts look as if they have had their lacquer knocked off but I don't think there is any underlying damage there.
Back to Top
  Share Topic
