AEVA Homepage
Forum Home Forum Home > Production Electric Vehicles > BMW
  New Posts New Posts RSS Feed - i3 wheel alignment
i3 wheel alignment
 Post Reply Post Reply
Author
Message
g4qber View Drop Down
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Topic: i3 wheel alignment
    Posted: 05 August 2015 at 7:19am
$166.70 - wheel alignment check KDS
$150.03 - adjusting rear axle and front axle
$31.67 - tax
$348.40 total
2011 i-MiEV - 87k kms
2014 i3 REx 90k kms
Back to Top
offgridQLD View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote offgridQLD Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2015 at 6:38pm
Wheel alignment check KDS $166.70 -
Adjusting rear axle and front axle $150.03 -
Knowing you could have got it done at Bob Jane for $ 60 priceless.
Back to Top
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2015 at 1:18am
Bob Jane don't have the i3 specs
2014 i3 REx 90k kms
Back to Top
bladecar View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote bladecar Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2015 at 6:58am
Bob Jane should obtain the i3 specs (if when you take out a contract to buy your car, you subsequently own it).
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote offgridQLD Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2015 at 5:55pm
I'm sure you can find out the specs.
Even if for some silly reason you cant. Perhaps while you know it's been set now (assuming they actually did anything). Take your car to BobJane or some other independent shop and get them to put it on there wheel alignment machine and print out the readings. Then next time you have reason to believe you need a wheel alignment then you have the specs.
Then again if your happy paying five times more than you should just continue to take it to BMW.
Back to Top
reecho View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote reecho Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2015 at 5:57pm
Wheel alignment huh...
Was it out from the original spec?
Generally it changes if either you hit things strong enough to bend components or suspension parts are wearing and changing geometry.
The latter is generally a warranty item.
Back to Top
  Share Topic
This page was generated in 0.234 seconds.
