AEVA Homepage
Forum Home Forum Home > General > EV Racing
  New Posts New Posts RSS Feed - Help Ripperton Build a New Battery!
 Post Reply Post Reply
Author
Message
jonescg View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonescg Quote  Post ReplyReply Direct Link To This Post Topic: Help Ripperton Build a New Battery!
    Posted: 31 May 2016 at 2:46pm
https://www.gofundme.com/275frfch
Hi everyone,
At Mallala, the electric bikes set some blistering lap times - a testament to the technology and the dedication of the builders and the riders.
This class is the only true prototype motorcycle racing class in Australia, and it's electric. The promoter of the series doesn't do much to promote the electric class, so it's entirely up to us to make it what it is (more on that in another post).
But Ripperton's machine suffered a major battery failure after it's rider, Brad Swallow set a brief record lap in race three. Three groups of cells were damaged and the repair job will be costly. If Ripperton can't get his bike on track for Queensland, we'll have another two or three bike show and the class will undoubtedly get cut.
So please help me help the competition, and get Ripperton on track in a month's time!
Chris
Back to Top
TooQik View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote TooQik Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 3:31pm
Does he know what the underlying cause of the cell failures were?
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonescg Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 4:04pm
They were a mixed bag of used and very used cells. Plus he's hitting them far harder than they probably should be. Low voltage, high powered packs mean the currents are really high. So the quality of your conductors is critical. We've had some disagreements on how a pack should be built, but I'd say the main issue was just the age of the cells.
Back to Top
g4qber View Drop Down
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 4:19pm
How much $$ needed ?
2011 i-MiEV - 87k kms
2014 i3 REx 90k kms
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonescg Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 4:23pm
Click on the link and read about it
Back to Top
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 4:27pm
Aha $5000. $815 in now
2014 i3 REx 90k kms
Back to Top
RIPPERTON View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote RIPPERTON Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2016 at 8:22am
Hi
a new set of 520 4Ah cells from YGS will cost $9000AUD ($6300USD) shipped.
Thats 8.4kWh 42s12p. the current pack was 7kWh and is still charging up to 4.2v each cell so I am building a new 12p pack with the used cells.
The main reason the pack keeps blowing up is I have turned the power settings in the controllers up to 100% both motor and battery current. Plus Brad rides harder than I do and he certainly knows how to use the regen. Listen to the onbike video, you will hear the motors moaning under brakes.
https://www.youtube.com/watch?v=k2l2QQt02as
Chris has found earlier that a lot of heat is released through the tabs but in my initial Flir camera tests most of the heat was in the skin, thats why I never built packs with tab cooling only skin cooling.
Whilst working on the pack at Mallala I noticed that the busbars wernt cooling down. Over a period of 2 hours there was continued heat being pumped into the busbars so its now clear to me that because the tab is connected to all inner foils, they are capable of removing heat from the core of the cell. If you check out the build thread on DIY you will see the new design of busbar.
http://www.diyelectriccar.com/forums/showthread.php/ripperton-electric-track-bike-41173p120.html
Many thanks to Chris for having the magnanimity to start the GoFundMe campaign, it might not bring in a new set of cells but will certainly help with the financial hole Im in as not having a job right now will help get the new pack finished in time for the next race in QLD.
Edited by RIPPERTON - 05 June 2016 at 8:23am
2013 eFXC Champion
Back to Top
  Share Topic
This page was generated in 0.250 seconds.
