AEVA Homepage
  New Posts New Posts RSS Feed - ecectric work buggy controller
 Post Reply Post Reply
Author
Message
drspastic View Drop Down
Moderated
Moderated
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote drspastic Quote  Post ReplyReply Direct Link To This Post Topic: ecectric work buggy controller
    Posted: 07 June 2016 at 3:37pm
hi, i got a pile of wheelchair parts and i made a 2 driven wheels buggy with front castor style pneumatic wheel so i use the original controller (shark11 i think)
because the buggy needs more power off road, i want to add a powered trailer section and lose the front castor so its more like an articulated steer loader.
2 separate controllers will be a pain to work, so what suggestions have you guys?
will i need a computer to work out the steering or just link the data lines from one joystick to the next.
the current buggy is fairly ok off road but needs more grip. also a trailer to be useful.
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adverse Effects Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2016 at 1:26am
the control unit most likely wont be able to supply more power so you would ether need a full 2nd system and some how link them as the default control stick has a computer of its own built in to it and will most likely spit the dummy if you try to hook it up to a 2nd drive computer
you would most likely need to create a full control and drive system from scratch to work with 4 wheel drive and then add in another separate drive system for the ram / or what ever you are going to use for the articulation system
Back to Top
Moderated
Moderated
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote drspastic Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2016 at 2:49am
i wasnt thinking to need a ram to steer as the front and back have their own controller. the system is from an invacare and comes 2x wheel-motors, controller, and joystick.
the join was going to be a universal coupling from a driveshaft but there is no suspension so it may need some flex.
synchronising the controllers looks to be a nightmare.
Back to Top
Richo View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2016 at 1:10pm
Long link for pdf
By wheel chair you mean mobility scooter?!?
I have done some minor repairs to one of these once.
They are pretty well integrated.
Trying to combine the controllers to one stick would be a waste of time.
Most of them still use crappy DC motors with a simple H-bridge controller.
It would be easier to get a DC controller off flebay and join them up.
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adverse Effects Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2016 at 1:36pm
and how do you see it controlling the "bend" in the middle? differential drive? and how are you going to control the very small amounts that would be needed?
Quote the join was going to be a universal coupling from a driveshaft but there is no suspension so it may need some flex.
so you want the center "joint" to not only flex left and right but up and down?
sooooooo what is going to stop the center dragging on the ground?
how much have you thought about this before you posted it?
Edited by Adverse Effects - 08 June 2016 at 1:38pm
Back to Top
  Share Topic
