AEVA Homepage
  New Posts New Posts RSS Feed - Do I need a new controller?
 Post Reply Post Reply Page  <123
Author
Message
Richo View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2017 at 12:46pm
Originally posted by Paul9 Paul9 wrote:
How come it worked fine for the last 7 years when wired the same way?
I thought the issue was zapping not a functional problem.
You would have to remember over the last 7 years if you actually touched the a traction pack terminal and exposed chassis.
And it would have to be 72V+ differential to perhaps even to notice it.
So it is plausible you never noticed.
There are plenty of ways to isolate a shunt.
Personally I'd rather isolate the signals rather than the TBS power.
This way the gauge is low voltage.
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2017 at 12:56pm
I use a 5:1 voltage prescaler.
Yeah so even this will cause a leak - not just the shunt.
It wont matter if it's the + or - wire connected to the traction pack.
Back to Top
Paul9 View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul9 Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2017 at 6:38pm
Thanks guys,
The problem with my understanding is that over the last 7 years I have fiddled around with wiring in the car. Bear in mind the "I" in the sentence above knows nothing about electrical wiring. The chances of me NOT having touched the TRAC pack, and body of the car, simultaneously, at least 20 times, is a million to one. But not one zap!
The people (experts) Johny contacted maintain that the TBS Pro has always connected HV and 12v. Why, after 7 years, have I only, in the last two months got zapped 4 times!
Maybe I just disconnect all the wiring between the TBS and the pre-scaler (and the prescaler and its connections) and re-wire? There is a connector strip between the TBS and the pre-scaler which appears a bit dirty - I better clean that too?
Thanks again people,
Paul
Back to Top
Peter C in Canberra View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter C in Canberra Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2017 at 6:43pm
I think the TBS pro was designed at a time when traction packs were of sufficiently low voltage that having a link from 12V to traction battery did not introduce a safety risk. For higher voltages such as 120V or 144V you should keep them separate.
LiFePO4 '91 Daihatsu charade, May 2009 AND iMiEV Nov 2013 on the ACT's 100% renewable by 2020 power.
Back to Top
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul9 Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2017 at 12:25pm
Thanks guys - at least I know which area to attack!
Paul
Back to Top
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2017 at 12:53pm
Well as I said you would have to touch the "right" terminal to notice.
Not all terminals will have a sufficient voltage differential to actually zap you.
Add to that your probably doing more pack work recently than in the last 7 years due to replacement/adding cells.
It is possible that there is a fault in the module that will give you a more noticeable zap.
Doesn't really change the outcome.
Back to Top
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul9 Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2017 at 6:52am
Thanks Richo, I appreciate the advice (and your previous advices).
Paul
Back to Top
  Share Topic
