AEVA Homepage
Forum Home Forum Home > Production Electric Vehicles > Tesla EVs
  New Posts New Posts RSS Feed - Charging-J1772 Adapter & Better Place Stations
 Post Reply Post Reply
Author
Message
Mircea View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Quote  Post ReplyReply Direct Link To This Post Topic: Charging-J1772 Adapter & Better Place Stations
    Posted: 26 November 2015 at 11:28am
Hi All,
I managed to get my hands on a Model S. Now, I have a couple of questions:
Is there anyone that has bought a decent and safe J1772 Adapter and used it
successfully on their Model S?
Is anyone aware if the Mennekes charge stations (mainly in Canberra but other places as well) that Better Place installed are still working? Plugshare says: "only available for members before BetterPlace went bust" but I heard conflicting information.
The portable charger - it can be broken down into two parts - the part that connects to the car and the part that connects to the power socket. Is it possible to get that power socket-to-adapter in a different plug style? I am thinking 450V tri-phase or J1772maybe?
Tesslaa
Back to Top
Johny View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johny Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2015 at 11:44am
I was under the impression that Australian Teslas came with a J1772 adapter.
https://my.teslamotors.com/forum/forums/tesla-j1772-adapter
Edited by Johny - 26 November 2015 at 11:45am
Back to Top
Gabz View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gabz Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2015 at 11:55am
Johny American Teslas don't get confused. we have euro teslas. if the betterplace stations are working you'll need a type 2 to type 2 cable available form tesla directly but more importantly you'll need a RFID card for betterplace.
a J1772 male vehicle inlet to Type 2 female vehicle outlet (J1772 adapter) are not approved of in the standard. therefore can't be certified and it's hard to qualify the use of the word "safe"
There is no pigtails for your portable charger for australia besides the one you brought with your car.
Back to Top
MDK View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (1) Thanks(1)   Quote MDK Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2015 at 11:57am
The Australian Model S does not come with a J1772 adapter, but you can buy one from a local Tesla owner and enthusiast at EVNomics
This will allow you to charge from chargepoint stations at up to 32A even if you don't have optional "second charger" installed in your Model S.
With other adapters your car may only charge at 16A due to the way Tesla on-board chargers are wired - unless you have the second charger.
I have one of these adapters and mostly use it for testing the J1772 charging stations on the RAC Electric Highway
The same company is currently making and testing adapters for the Tesla-supplied Mobile Connector that will allow you to plug into 20A or 32A 3phase sockets.
Note that the mobile connector itself is limited to 16A, but 20A and 32A sockets appears to be the most commonly found and aren't interchangeable.
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2015 at 7:52am
Thank you guys, I really appreciate it!
Now let me get this straight:
The BetterPlace stations do not charge unless you have an RFID card, right? Which I don't so assume buying the cable is pointless? Or maybe a card can be sourced from some enterprising person? :)
Which standard does not approve of the J1772? The J1772 standard I assume?
In terms of "safe", I am concerned about frying up the electronics in my shiny new toy and getting warranty voided by the use of a cable that was not sourced from Tesla. Now THAT would be unideal.
I have the optional second charger installed so amperage should not be an issue.
MDK, Thanks for letting us know about the RAC electric highway. That is one super-cool idea. Is that your Tesla in the video? And I assume since you use that cable, it does not pose damage risk to the car?
Thanks again guys!
Tesslaa
Back to Top
MDK View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (1) Thanks(1)   Quote MDK Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2015 at 6:54am
Yes that's my Tesla, and yes the J1772 adapter is fine - although the Electric Highway also has DC fast chargers at each location (which is 6 times as fast as the J1772) so I mostly use that (via CHAdeMO adapter from Tesla) with the J1772 adapter only for testing (and as a backup in case the fast charger is already in use or not functional)
Back to Top
Gabz View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gabz Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2015 at 6:59am
yep so betterplace no good unless you have an RFID. best to start by asking at the places they are located to see if they have one on site. most places signed up for one because they have an EV and kept them because they still work for them at least.
I doubt the cable will fry anything enough people have been successful with it. but yes there are potential warranty/insurance concerns as tesla can say that's a non approved cable and the owner of the charging stations can also say you used a non approved cable.
FYI J1772 and mennekes are all covered in the IEC standard 62196. which I believe Australian standards have adopted unaltered.
Back to Top
alexeiw123 View Drop Down
Status: Offline
Post Options Post Options   Thanks (1) Thanks(1)   Quote alexeiw123 Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2015 at 7:30am
The J1772 adapter from EVNomics (as mentioned by MDK) is the one you want.
The intuitive way to connect the L1 pin on the J1772 side is to the L1 pin on the mennekes side, however this means you would limit the max charging rate available. This is because the tesla on board charger is actually three chargers, one for each 'phase'. If you have dual chargers in your car, you would likely never notice that limitation.
Anyway, the EVNomics adapter bridges L1 on the J1772 side to L1,L2,L3 on the mennekes side, and you get the full capability of the on board charger.
Back to Top
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2015 at 9:47am
Cool.
Thank you for that guys, appreciate it.
The EVnomics cable looks very short on the website. MDK, would I need an extender cord for that or you can easily use it?
In other news, I just did a weekend Can to Mel return run and the superchargers came in superhandy.
I found a very small difference (in terms of convenience) between driving the EV and a petrol-powered car. The difference was easily offset by the free cost of travel.
Tesslaa
Back to Top
MDK View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDK Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2015 at 9:53am
The cables on J1772 charging stations (at least the ones I've used) are quite long, as they are designed to plug into cars without requiring an adapter or extension lead.
The EVnomics adapter plugs into the end of the existing cable.
Back to Top
antiscab View Drop Down
Admin Group
Admin Group
Forum Admin
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2015 at 8:12am
If that is the case - see if they would be up for just supergluing the RFID tag to the sensor
2011 Blade Electron mk6
2007 vectrix - 117'000km
1998 Prius - needs batt
Back to Top
MDK View Drop Down
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDK Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2015 at 8:47am
I wonder if it's possible to reprogram the Better Place charging stations to work without an RFID tag (or to allow "any" RFID tag)
It would be interesting to pull one apart and see if there's an Ethernet or USB port (or similar)
Back to Top
Peter C in Canberra View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter C in Canberra Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2016 at 12:48pm
The Better Place chargers in Canberra are now supposed to be working with a card from ACTEW. I was given an ex-Better Place cable to try with my iMiEV but could not get it to work. I am just now investigating inside. The J1772 end comes apart. The Mennekes end seems welded. At the J1772 end there is an encapsulated little board inside the plug which might be a RFID receptor thingy and the cable is numbered. Perhaps the RFID was cable-specific? I am looking to see is that can be bypassed so that the cable can be just wired up to work with the ACTEW posts.
LiFePO4 '91 Daihatsu charade, May 2009 AND iMiEV Nov 2013 on the ACT's 100% renewable by 2020 power.
Back to Top
  Share Topic
This page was generated in 0.234 seconds.
