AEVA Homepage
Forum Home Forum Home > Production Electric Vehicles > Holden/Chev Volt
  New Posts New Posts RSS Feed - A closer look at the volt RCD tripping issue
 Post Reply Post Reply Page  <1 345
Author
Message
g4qber View Drop Down
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2014 at 6:51am
looks like it could just a coincidence.
volt was behaving itself this morning.
plugged in & out 3x
first time, it green LED flashing indicated fully charged.
2nd n 3rd time, volt went into green steady charge mode.
Back to Top
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 14 April 2014 at 5:08am
tripping is a blessing in disguise
tests the RCD and makes sure that it is working.
used Nissan 15A evseupgrade this morning.
had to reset @ meter box.
previous nights, Mitsubishi 10A EVSE had been charging successfully.
this is when the battery is depleted a bit.
Edited by g4qber - 14 April 2014 at 5:09am
Back to Top
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2014 at 12:13pm
got my 32A circontrol e-station wall box back.
now using it to charge the volt at 14A.
Went up to Yanchep Shopping Centre last Saturday.
Used the 15A to 10A adaptor from Jaycar, but since the volt draws 14+A unlike the imiev's 13-A, the adaptor's over current circuit trips after 5-10 mins
had to use the volt's 10A unit to charge.
wish that bollard would be upgraded to 15A
currently running on 20A circuit with 2x 10A sockets
I guess this will be for the future when 2 bays may be allocated for EVs.
Edited by g4qber - 17 May 2014 at 12:17pm
2011 i-MiEV - 87k kms
2014 i3 REx 90k kms
Back to Top
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2014 at 4:47pm
Just met a guy last night at the Perth AEVA monthly meeting.
His hunch is that it is an earthing issue on the Volt. This was already found by e-station's testing in 2012.
The HVAC freezes and the indicator Freeze also sounds like Earth is stuffing up the computer.
This guy has found that corrosion has occurred on vehicles that have odd auto electrical issues.
He as come across many vehicles that are cured by terminating earth connections properly.
Edited by g4qber - 10 September 2014 at 4:48pm
2014 i3 REx 90k kms
Back to Top
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2014 at 3:03pm
Volt trips Bmw Delphi clipper creek 8a evse
Also managed to get 10 amp Holden evse to fault today
Buzzing evse from city motors. Getting a replacement.
2014 i3 REx 90k kms
Back to Top
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2015 at 6:45am
Volt works ok with antiscabs emw 80 amp unit
Also didn't trip on his circuit when charging with Mitsubishi evse.
He has industrial rcd which may have greater spike tolerance.
2014 i3 REx 90k kms
Back to Top
antiscab View Drop Down
Admin Group
Admin Group
Forum Admin
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2015 at 8:25am
The RCD attached to that circuit is a 3-phase 32A MCB with a 30mA trip current
The EMW still has an 80A pilot signal, but it's on a 32A circuit (fed by 6mm2 TPS).
One day I'll get around to adjusting the pilot signal, but there's only one car at the moment that can draw more, and that's a Tesla. I don't know anyone with a Tesla :p
2011 Blade Electron mk6
2007 vectrix - 117'000km
1998 Prius - needs batt
Back to Top
AEVA Member
AEVA Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote g4qber Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2016 at 5:46am
2014 i3 REx 90k kms
Back to Top
  Share Topic
This page was generated in 0.217 seconds.
