AEVA Homepage
  New Posts New Posts RSS Feed - 0-10v throttle
0-10v throttle
 Post Reply Post Reply
Author
Message
Madmax View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Madmax Quote  Post ReplyReply Direct Link To This Post Topic: 0-10v throttle
    Posted: 22 May 2016 at 9:19pm
where/what is a good source for a 0-10v throttle?
cheers!
Back to Top
jonescg View Drop Down
Avatar
Status: Online
Post Options Post Options   Thanks (1) Thanks(1)   Quote jonescg Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 12:08pm
Wouldn't any throttle work? They're just voltage dividers. Do yoy mean a 10 kOhm potentiometer?
Back to Top
Richo View Drop Down
AEVA Member
AEVA Member
Avatar
Status: Offline
Post Options Post Options   Thanks (1) Thanks(1)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 12:30pm
There not all pots.
Half of them will be hall type which are 5V.
If you can find the pot type it should work on 10V
I'll assume you're wanting one for an Industrial VFD which generally use 10V.
http://www.evworks.com.au/ev-works-throttle-box-0-5kohm-2-wire-resistive-typ
You will need to solder the third wire on for it to be suitable for a FVD.
Back to Top
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Madmax Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 5:14pm
0-5V should also work (simply config the controller).
Richo, yes its for an industrial controller... I have a couple of Dunkermotoren BG75x50PI motors which have integral controllers that I'm testing for a project.
Back to Top
mortonpiers View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote mortonpiers Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2016 at 2:03pm
You could try these:
https://www.motiondynamics.com.au/hall-effect-foot-throttle-metal.html
Back to Top
  Share Topic
